Question about Mitsubishi WT-46807 46" Rear Projection Television
Just back from the shop and out again!
After 5 hours playing beautifully there was a crackle sound, the volume screaming all the way up. I tried turning the volume down with the remote but still screaming. After a minute or 2 the sound went completely out. After another 2 or 3 minutes, the screen went black. I let it set overnight and this morning when I turned it on, there was a blue area in the middle and thin blue and green lines orbiting about 1/2 way up. Please help. I just gave a local repair man 425.00. He said there was fluid that damaged power control. he changed that. Still having a problem Mitsubishi said maybe the signal module was bad. There was only 1 in stock and no more to be manufactured. It was damaged in shipment. He put mine back in and it was working a whole week in his shop.
    Genius:
  • 1,153 Answers
Fluid leakage would definately cause this problem. Also it sounds like audio problems on the audio board, did they say what board was leaked on? You mention signal mod.
Posted on Aug 13, 2007
There is a crackle when i turn the volume knob.
First unplug it. Sounds like you need to spray some tuner cleaner in the pots that are crackling. Pull the knob off and you should be able to use a spray can of tuner cleaner with the straw that comes with them to spray into the potentiometer , then rotate the pot several times while it is still wet. After cleaning them all, wait 10 minutes and then try.
Jan 09, 2014 | Marantz Vintage Model 2220b Stereophonic...
My father has a Dynex LCD TV, Model DX-37L130A11 Rev A, sticker says 10H07-Rev A. Manufactured August 2010, Lot #: 205204 XHT 100453. A few days ago he said the audio started emitting a loud, cracking...
It sounds like you've done quite a bit of troubleshooting, which I applaud you for doing. Have you tried power cycling the TV? Simply turn off the TV, unplug it (and any components connected to it), then plug it back in and turn it on after a minute. See if this corrects the issue. If it doesn't, then I would recommend calling our Product Support team to schedule repairs at:
U.S., Canada, & Puerto Rico - 1-800-305-2204
Mexico - 1-888-882-7326
daily from 7 am - 12 am CT.
Sep 04, 2013 | Dynex Televison & Video
Tvee 20 subwoofer has distinct hum noise. Any advise?
1.Check the input cable or change it and see the result.
2.Test the subwoofer to a computer.
May 29, 2011 | Boston Acoustics TVee Model Two TV...
My ipod crackles and my hearing seems to be getting damaged
Id say you should go see a doctor. But for now id say that you should do your best to not listen to it for a while as it can affect hearing. try to use full on speakers if you can. On you tube there are a few Sub-Woofer sound tests you can do. Try playing one (low volume) and repeat. (not a song one)
http://www.teenbuzz.org/ also to hear which frequencies are out of range to you click here. ( click the second icon on the list further down the page)
But yeah go see a doctor. Perhaps some ear drops.
Sep 01, 2009 | Apple iPod touch
After about an hour the tv soaun makes a
  1. The most likely cause of this is dirt/dust in the volume potentiometer. When the set gets warm it starts to crackle. You can try bllowing or sucking the dist out of the set. But the better option is to have the sound module replaced
Aug 21, 2009 | Sansui HDLCD3210 32 in. LCD TV
Screaming crackling noise when very hot
Crakling sound is a symptom of loose or cold solder in amplifier section where the STK IC or Darlington transistor is located .You better re solder all parts joints there in order the crackling sound is gone.
Hope it may help you;
Regards;
VOTIT
DON'T FORGET TO RATE;
Jan 08, 2009 | Audio Players & Recorders
Audio crackles at normal volume with game discs
they said there would be a problem for LG tv's try going to your settings audio settings and change stuff around
Jun 24, 2008 | Sony Playstation 3 (PS3) Console
SoundDock produces only harsh crackling sound
Yeah i had that same problem. You know the chord? The cord you plug in from outlet. The square cord you plug into your speakers.. yeah the "DC outlet" is supposed to be UP. if you have it the wrong way in there it wont work and will make a crackling sound.
Apr 30, 2008 | Bose SoundDock Digital Music System for...
Stereo receiver crackling noise
open it up and spray it with contact spray. move left and right and then spray again. this will normally do the trick. the crackling noise comes from standing in the same position for to long.
Aug 13, 2017 | Audio Players & Recorders
Mitsubishi WT-46807 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
