Question about Aprilaire 700 Humidifier
FURNACE RUNNING LOUD
WHENEVER I TURN MY HEAT UP, MY FURNACE IS ALL OF A SUDDEN RUNNING LOUD. THE FLOOR IS SHAKING, THIS DID NOT HAPPEN LAST WINTER, HOWEVER THE BLOWER DID GO OUT LAST YEAR AND IT HAD TO BE REPLACED. THE FURNACE IS ONLY 2 YEARS OLD.
  • David Beebe May 11, 2010
    is it fuel oil? Natural Gas or LP?
    President:
  • 1,304 Answers
Sounds like either the motor is off balance
or is going bad again
either way id be on the phone to the guy who did the rapair
more than likely the set screw on the sqiral cage came loose and now its vibrating
Posted on Oct 06, 2009
I have a 1099 general powered humidifier making a loud humming noise.
there are no moving parts in that humidifier other than the solenoid and it only moves open or closed are you sure the noise isn't caused by something else, maybe something close or even the furnace
Feb 23, 2014 | General Filters 1099-LH Humidifier
My aprilaire model 560 is constantly clicking loudly. I read about the click point but despite where I set the dial it is constantly clicking whenever the furnace kicks on. What can I do?
Check all wire connections for tightness. Those solenoids on the humidifiers will eventually need to be replaced. Try turning the dial all the way up to the test position if it is still clicking you may just need a new solenoid.
Dec 10, 2013 | Aprilaire 600 Humidifier
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
Nov 06, 2013 | Aprilaire 700 Humidifier
Before we replaced our furnace, I had to replace the transformer almost every year. When the new furnace was installed last year, the transformer disappeared. Now with winter coming on, the 550 hasn't
Hello, seems like there is no way to turn on the humidifier. There would either need to be a new transformer installed, a current sensing relay, or a sail switch to activate the humidifier when the blower motor kicks on.
Nov 22, 2011 | Aprilaire 550 Humidifier
My aprilaire humidifier is 30 years old. Put in when the original furnace was installed. The water seems to be running through it and I have had the pad replaced, but I am still getting a lot static...
If the humidifier has a 6" duct on one side, this must be open in winter you should find a handle, if there is not any label, move it so the handle is parallel to the ductwork.
If the humidifier do not have a duct on one side, it must have a fan, if you can't hear it working, probably is time to get a new humidifier, and make sure contractor check furnace heat exchanger for CO2 leaks.
Jan 15, 2011 | Humidifiers
Have a large new house with lots of vinyl clad wood double hung windows on a lake temp today this am is 0 F we have a HRV system house temp is 66 downstairs and 58 upstairs heating with a heat pump and...
Really not efficent to run a heat pump at those temperatures. Below freezing is not good for the compressor in the outside unit. The humidity in the house with the low temp. is causing the condensation on the windows to freeze. Kinda like an air conditoner does in the summer without the freezing humid air from the house goes over the cold a/c coil and the moisture condensates on the coil running down to drain pan. raising the temp. in the house and lowering the humidity should help. I would also recommend running the electric heat in low outside teperatures.
Dec 17, 2009 | Aprilaire 600 Humidifier
Water runs out back humidifier into plenum & onto floor
Hi John Your whole question did not show up (maybe you can re-post) . I can answer what part i understand though. If the humidifier was wired in right it will not send power to the humidifier until the furnace is on, and calling for heat. This stops the unit from working in the cooling mode in summer.Make sure your furnace filter is clean as well
Hope that helps
Mar 05, 2009 | General Filters 1042-LH Humidifier
Aprilaire 760 keeps running.
The humidifier should not turn on untill the furnace blower starts. Since the fan stays on. does the solenoid valve also stay on? If they both stay on you probably have a bad humidistat. If only the blower stays on then the circuit bourd in the humidifier is defective.
Good luck
HVAC Teacher
Feb 06, 2009 | Aprilaire 700 Humidifier
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
AprilAire 760 not running after installing new circuit board
I called the service company that put in my new furnace (FAmily Heating and Cooling in Detroit, very highly recommend these people)
Anyway they sent out a second service tech who determined that I would be better off having the humidifier wired to go on whenever the furnace fan was running instead of using the humidifier signal from the circuit board on the furnace. After he changed the wiring the unit runs fine. It is pretty likely that the circuit board was bad also.
Nov 27, 2008 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
628 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
