Question about Bunn BT10B Coffee Maker
At first it leaked and now it will not heat up.
I have a BT10-B what is the warranty. We have had this for three years and have had it leaking most of that time, and recently refusing to heat up I am disappointed.
This unit is under the Bunn recall, contact them. https://www.regcen2.com/info.aspx
Good luck
Posted on Dec 14, 2008
Ac condensing coil has a leak how to fix and where is it located
You can not fix a leak in a coil. I fixed one coil in 10 years and it's because it was brand new and I put a screw in it. I am a seasoned brazer with years of experience, your coil can not be repaired, it needs replaced. Hopefully it's under warranty, that's $500-700 vs $1500-1700 approximately.
Aug 09, 2017 | Heating & Cooling
Is a kaz water tank leak under warranty?
I doubt if there is any warranty on this now. It has been over three years ago.
May 18, 2017 | Honeywell Humidifiers
LB2280 leak
If this is instant heat faucet, then contact manufacturer.
Most these faucets have 1 year limited warranty
Replace faucet?
http://waterheatertimer.org/How-to-install-point-of-use-water-heater.html
Gene
Water Heater Timers Save Money
Dec 02, 2014 | Franke LB2280 Instant Hot and Cold Water...
I have a Bunn BTX-B. It just stopped heating the water. I received it as a Christmas gift, purchased on Dec. 24, 2010, from Lowes. I do not have the receipt. I emailed customer service. They sent me two...
Warranty is 1 year parts and labor, 2 years parts only and 3 years for control boards. That model does not have a control board. You could have a bad thermostat, bad high limit, bad thermal link or bad element. Without you having a multimeter anSd the knowledge of how to use it properly it would be best to replace the unit.
Dec 27, 2012 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
What would cause hose from pump to tank on a porter cable pancake comressor get extremely hot when running
It is normal for the line going from the compressor to the tank to get very hot in all air compressors. Compressing air creates allot of heat. It will get hot enough to cause burns if touched.
Nov 18, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I have a Bunn BT10-B coffee maker. I need the two rubber parts to replace the old ones which is causeing it to leak.
If you will call 800-352-2866 with the model and date code, we will be happy to help you.
Jun 15, 2010 | Bunn BT10B Coffee Maker
When parked the heater does not work. Works fine if car is moving
Yes, Low coolant.
Leaking water pump or leaking rear head gasket very common on this engine.
Would be under the 5 years / 100k miles factory warranty.
Oct 07, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
Duramngo cooling system problems (2001, 4.7 L)
mcdevito75 here, Part of the reson could be manufactures are useing alumimum a lighter metal in many parts of their cars, and alumium does not hold up to heat very well. In my opinion your cooling system is just too hot, Part of some auto radiators are made from plastic, also not good for the heat build up in your cooling system. First I would get a very good brand of anti freeze a brand that says on the container it protects aluminum, and mix a specs. Then I would replace the vehicles thermostat from the 195 dergree the factory recommends down to a 180 degree, this will not hurt the vehicle or computer, lastly I would change the radiator cap the one inuse now could be building too much pressure in your cooling system. About your warrantee any Durango Dealership should honor it, unless it"s worn out. (over)
May 29, 2009 | 2001 Dodge Durango
Swimming pool solar heater panels freeze problem
Depending on the manufacturer, your solar panels may be replaced under warranty. Our installer says that once the panels begin leaking, they tend to deteriorate fairly rapidly. For example, three leaks the first year, 7 leaks the second year, 30 leaks the third year.
Many solar panels are warrantied against freezing, but that is not likely to be the future of the warranties, because they inevitably DO freeze and leak.
If there are just a few leaks, it is easier to fix them - a Fafco Solar panel repair kit can usually be bought from your installer for about $25.00.
If you turned the pump on to manual to circulate the water through the panels, that should prevent a freeze - but will cost you the electrical cost to run the pump.
Our experience has been that it is better NOT to drain the panels - we had many fewer leaks the years we have not drained the panels, despite occasional hard freezes in our part of California.
In addition, your rooftop installation should help radiate some heat up to the panels to keep them from freezing.
Check your warranty and get the panels replaced if there are more than a few leaks.
Mar 21, 2009 | Fafco Deluxe Solar Panel Heating System 1...
Three way solenoid valve
All you can do is replace the part. I am not sure on frigidaire parts, they use to have 1 year warranty on replacement, some companies have gone to 90 days.
Jan 07, 2008 | Frigidaire FSC23F7D Side by Side...
Bunn BT10B Coffee Maker Logo
162 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
