A vertical red line has appeared through the middle of the display on my Samsung LCD TV LE32M87BDX/XEU. It is only 18 months old and I have not been able to find any solution to this problem.
-   I just bought yesterday Samsung LN52A650 LCD 52" TV from The Brick and thin vertical red line appeared on the middle of the screen. Line disappered after a while when TV was running. I don't know what is the problem.
-   same problem, red line down the right side. it's only when the cable is on, doesn't happen when the dvd player is playing nor when i'm playing my Wii. -   actordenato
Dec 07, 2008
-   same red line on 42 inch plasma tv only 2 months old-   Guest
Nov 30, 2008
-   Our Samsung LE32R41BD 35 in HD-TV has a single red vertical line through it and we have no idea why.-   Blinck22
Hola mi nombre es javier y tengo una tv de proyeccion de 52", de la nada ahora no enciende, a...
(More)(More)
Hola mi nombre es javier y tengo una tv de proyeccion de 52", de la nada ahora no enciende, a que se debe este problema?? alguien me podria ayudar por favor?? tendra arreglo??
gracias
buenos dias mira mi pregunta es .. tengo una tv de proyeccion samsung de 52 pulgadas pero traia un...
(More)(More)
BUENOS DIAS MIRA MI PREGUNTA ES .. TENGO UNA TV DE PROYECCION SAMSUNG DE 52 PULGADAS PERO TRAIA UN POQUITO DISTORCIONADA LA IMAGEN DE UN LADO (SE VEIA DOBLE DE LA MITAD DE LA PANTALLA PARA EL LADO IZQUIERDO) Y TUBE LA GRAN IDEA DE MOVER EL REAJUSTE DE LOS COLORES Y LA DEJE PEOR POR QUE AHORA TODA LA PANTALLA SE VE DOBLE O TRIPLE POR LO DE LA CONVERGENCIA Y APARTE DE TODO ESO LE CONECTO EL CABLE O LA ANTENA Y SE ME APAGA SIN ANTENA O SIN CABLE NO SE APAGA... CUALQUIER COMENTARIO TE LO AGRADEZCO... GRACIAS
I bought a Sanyo DP46849, lcd tv, 1080. and I'm getting a fuzzy picture. It helps when i put my...
(More)(More)
I bought a Sanyo DP46849, lcd tv, 1080. and I'm getting a fuzzy picture. It helps when i put my cable receiver on hd channels, but even my blu-ray looks better on my 720 plasma???? any suggestions, I bought the tv only 2 weeks ago and have been noticing this since then, but I just got cable yesterday.
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
I have a Panasonic TH-42PZ70BA Plasma TV. Went to switch it on & it cut off instantly with...
(More)(More)
I have a Panasonic TH-42PZ70BA Plasma TV. Went to switch it on & it cut off instantly with the power button flashig red. Tried unplugging and leaving but still the same
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
