Question about DeLonghi MW 605 Convection/Microwave Oven
Control panel Dear sir I bought a digital Delonghi microwave oven from England two years ago. Now I have a problem. This is the control panel dose not work and the lamb is turn on when the door is closed. I am from Egypt and I am now in Egypt. So I can not solve this problem. Please help me Yours, Galal
  • DeLonghi Master
  • 19,396 Answers
Try one of the following sellers.
Contact them and ask shipping fee to Egypt.
DELONGHI Spares and Spare Parts.
DeLonghi Microwave Spares, Spare Parts & Accessories
Posted on Nov 11, 2008
How do I set the clock?
There probably is a clock set button on the control panel.
Dec 29, 2015 | DeLonghi Microwave Ovens
My delonghi microwave is not working
Microwave ovens come with a standard 1 year warranty, take it back and see if they will help, since you are right on the line when it comes to time frame.
May 22, 2012 | Microwave Ovens
Hi, i have an ac925efy delonghi microwave oven, i bought it manufacturer refurbished and when i switched it on there was a big bang and a flash. it came from what looked to be the back top right hand...
From your description it is the magnetron that heats the food that has gone, I suggest that you take it back for a refund, because if you decide to fix it the repairs will run you more than what the microwave oven is worth.
Jan 16, 2011 | DeLonghi MW 535 Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
My microwave bulbs don't work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 21, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
GE JVM1640 won't heat
These microwave ovens have a series of door switches. One of yours has gone bad or a plastic finger on your door mechanism that pushes the switches is worn or broken off. They are commonly called NC or NO swithes some ovens have up to 6 of these working together.If you have no expertise in this field consult a repair shop. Please rate me
Comment posted on Jan 12, 2009 there are two types ,normally open and normally closed, NO NC . u have to check continuity on each one and each switch will have a diagram on the side showing its in use position. I hope this has been helpful
Jan 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JCPenney microwave oven model #5919 Electronics panel is failing. After unplugging to wipe it down, I cannot set any functions, the first of which is always the clock. The panel will let me enter one...
It sounds like moisture has gotten into the controls. If it can be dried with a hair dryer or the sun, that might work.
I used to work on a lot of these about 20 years ago, and if it needs to be repaired, I truly doubt that it can be done. One would have to replace several capacitors, at the very least.
Nov 04, 2008 | Microwave Ovens
DeLonghi combined microwave/grill/oven.
Found this posted in GE instead of DeLonghi but the basics are the same.
You say it stopped working - you mean it runs but doesn't heat?
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Unit does not turn off
open the control push boton and clean it one of the boton stoct.
Sep 19, 2007 | Panasonic NN-S254WF Microwave Oven
DeLonghi MW 605 Convection/Microwave Oven Logo
397 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
