Question about JVC AM FM CD DET FACE CAR STEREO
Tuning the JVC radio
When i try tuning the radio, the frequecies displayed are odd numbers only. So certain radio stations with even numbers cannot be tuned. i heard it might be set on US settings & have to change to UK. if this is the problem how do i change it.
  • 3 Answers
Hi, it depends were you got the radio from mine is doing the same its a grey product and comes from US or other countries.If you are lucky just hold and press the setup key for +- 5 seconds and it will jump to setting HH then press the + or - button were you change the radio, go to area and turn knop on radio to US or other country thats working for you. Hope it helps
Posted on Nov 26, 2008
  • james Mar 17, 2011
    My name is james in Kenya, mine had the same problem, just change the AREA from US to EU and there you are with Maina
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
How i change the radio station jump from jumping from odd numbers to even numbers for example i want these stations in my radio 102.0,98.0,92.0..etc
Tune into 102.0 then hold button "1" for a few seconds (you may hear a beep as it registers). Tune into 98.0 and then hold button "2" for a few seconds. Tune into the next station and then hold "3" and so on. Now when you press "1" it will go to 102.0 "2" will go to its' preset and so on.
Sep 26, 2015 | Cars & Trucks
When I try to tune in the station it only stops on odd numbers and not even numbers. How do I fix that
radio stations on FM are only odd numbers...
such as 102.1 102.3 102.5 102.7 102.9 103.1 103.3 103.5 etc etc.
Aug 08, 2010 | Alpine CDM-9821 CD Player
Fm touner act only on odd number like 104.1- 104.3
factory radios only tune into odd numbers... radios stations broadcast on odd numbers to avoid some frequency interference... ive only see a few aftermarket radios that tune to even numbers also
Nov 03, 2009 | 2004 Chevrolet Blazer
Changing tuning frequncy from odd to even No. Kenwood KDC-MP228
Most car stereo (stereos in general) won't tune to even numbers. If you're having problems tuning in your station then you're either too far away or you should take a look at your antenna.
Oct 27, 2009 | Kenwood KDC-MP228 CD Player
The radio does not search on even numbers (89,8) only on odds numbers (89,9) is it posible to chance that?? My car is 2006 Tacoma
Why? North American radio stations are only broadcast on "odd" frequencies - x.1, x.3, etc.
Jul 12, 2009 | 2008 Toyota Tacoma
I can not tune on even fraquencies
Thats USA tuning, you can only get those odd stations on that deck.
May 30, 2009 | JVC KD-S5050 CD Player
AM radio tuner set as MW tuner. How to switch to U.S.A. AM mode?
AM is just another name for MW. The Radio should tune to a strong signal regardless of the frequency the radio is set to. It should also sweep the entire frequency looking for stations. I'm assuming it has a channel scan setting, plus options to set a number for the station. AM/MW are very much dependent on the position of the either internal or external Ariel. If you have the radio in the wrong position or you have some electrical equipment nearby it could block the signal for the station you want, but not affect the others. Which might explain why it can't find the station you want.
May 05, 2017 | Philips DCM230/37 iPod Docking Executive...
Cannot tune to local stations
- The 0.2MHz odd steps are standard for US radios. Try resetting the radio (recessed button under the front panel) If this a US radio then this may not help. If you have lost the manual then go here:- http://books.jvcservice.com/booklist.asp?Model=KD-G400 Come back and say if this helped or not, I could dig a bit deeper.. -
Oct 04, 2007 | JVC Sirius KD-G400 CD Player
It only seems to tune in odd radio stations
Unless you're in Europe, it's not supposed to. No stations (in America) exist on even numbers.
Aug 29, 2007 | Pioneer DEH-P5900IB CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
472 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
