Question about Canon PowerShot A540 Digital Camera
Card Locked Ive had my Powershot a540 for quite a while and suddenly it shows that the card is locked and can not take more pictures. Ive checked it all around and its settings but I cant find the way to unlock it. My manual is missing. H E L P.
  • boricuautuad Nov 13, 2008
    Thankyou tgerblinger
    That was the problem.
  • jhoward336 Nov 16, 2008
    I have the same problem and I don't know how to interpret that solution. What is an allocator and how do you commutate it???
You have to check the card. somewhere on the card is a commutator you have to allocate it.
Posted on Nov 12, 2008
When I install a new SD card in my Canon PowerShot A540 it displays Memory Card Error Card Locked. I have moved the tab on the card and it displays the message regardless if the card setting. What
it seems to be the memory card slot is damaged normally 9 contacts connect with MC if any of it doesn't contact, will not work, open and takeout card slot if the contact is bend align it to touch the MC's contacts.
Sep 02, 2017 | Canon PowerShot A540 Digital Camera
My memory card is locked and i tried everything i have a canon a540 powershot and the memory card is a sandisk 8gb
Have you noticed the slider on the side of the card? This acts as a lock and might have been accidentally moved to the locked position, in which case you could just move it back to unlock again. Hope this helps.
Dec 27, 2010 | Canon PowerShot A540 Digital Camera
Canon powershot A540 I have tried to erase memory card but it says card locked. How do I unlock.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 17, 2010 | Canon PowerShot A540 Digital Camera
Memory card locked
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Feb 07, 2010 | Canon PowerShot A540 Digital Camera
A540 says "memory card error" " card locked" but 4gb card is not locked - can access card on card reader - copy on and off. a540 works with 2gb sd card no problem. please help?
The A540 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
Jan 13, 2010 | Canon PowerShot A540 Digital Camera
Formating a new card for the Canon PowerShot A540
Here is how you do it.
1) press the menu button.
2) scroll right to the Setup Menu
3) scroll down to format.
4) scroll right to enter Format Menu
5) scroll up to Low Level Format.
6) scroll left or right to add a check mark.
7) scroll down to ok and press the function/set button.
Sorry no one got to you sooner. Hope this helps you, and thanks for coming to FixYa. Don't forget to rate my solution.
Rob
Jan 08, 2009 | Canon PowerShot A540 Digital Camera
Canon powershot A540 digital ...problem it shown card locked
Remove the SD card from the camera. Look for the tiny slide switch on the side of the card. Slide this switch back to the unlocked position (opposite of whatever its at now).
Aug 01, 2008 | Canon PowerShot A520 Digital Camera
Canon A540
Try using a card reader until the problem can be resolved with your camera.
Format your memory card once you have the images backed up. Try another memory card to see if it works in the camera. If another one works, it is probably a faulty card, but if it doesn't you may need service for your camera.
Call Canon tech support if this doesn't work.
May 22, 2008 | Canon PowerShot A540 Digital Camera
There's a little switch on the side of the SD card. Remove it from the camera and find the switch. Normally, there's some very small printing next to it saying something like (Lock / Unlock).
Mar 27, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot A540 Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
