Question about Philips SA5125/37 MP3 Player
Problem of player
My gogear 1gb player is neither starting nor detected by computer for formating it wat to do??????? please suggest some solution as early as possible
  • 8,596 Answers
  • Try to connect the player to the USB port at the back of your PC if you connect the player to the USB port in front of your PC.
  • If a USB cable is needed to connect the player to your PC, use another USB cable and avoid the USB cable that is too long.
  • Uninstall the player and USB drivers from your PC and re-install them.
  • Posted on Dec 12, 2008
    I downloaded video from my computer to my gogear vibe mp4 player but will not play. ( file format not supported)
    well this are the only vid format supported by GoGear (MPEG-1, MPEG-2,MPEG4-SP, Motion-JPEG) if your file is not in one of those format you have to convert it. I suggest this converter http://thepiratebay.org/torrent/4434811/Super_(C)_Converter._Convert_Any_Format_To_Any_Format._For_Free.
    hope that helps...
    Jul 08, 2011 | Philips GOGEAR SA6045 MP3 Player
    My philips gogear vibe 8gb is brand new. I charged it and put on music and it was fine for an hour. But now it freezes on the 99% updated screen. I reseted it and i can still usb connect it but after it...
    Firstly, I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
    If that doesn't work, you can format the player. Provided its recognized by the computer. Contents may be removed by using this function. So make sure to back up your contents. Here is how to do this:
    Connect your GoGear player to your PC. On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format". Disconnect it once the format is complete.
    If that doesn't work, you can repair the player. To repair it you must have the software that came with the player or you can download it from the Philips suppot site. WWW.philips.com/support/. Players that start with SA1xxxx uses Device manager and the Players that start with SA2xxx uses Philips Songbird.
    Here is how to Repair your GoGear MP3 player using Device Manager:
    Launch Device Manager and click the Tool menu and select "Repair my Philips GoGear", then follow the instructions to perform the repair process.
    Here is how to Repair your GoGear MP3 player using Philips Songbird:
    Launch Songbird and then connect your player to your computer. Select "Repair my Philips GoGear" under the "Tools" menu. Follow the instructions given by the pop-up windows to perform the repair process.
    *Contents may be removed by using repair and format functions. So make sure to back up your contents.
    Hope this helps.
    Cheers..
    Feb 27, 2011 | Philips GoGear ViBE Digital Media Player
    My m.p.3 phillips gogear vibe now says :no space to build database,please connect to p.c. and create 100 mb free space,then turns off,please tell me what to do to get this to work again?
    If that doesn't work, I'd suggest that you format your player or repair it using Philips songbird. Contents may be removed by using this function. So make sure to back up your contents.
    Format:
    Repair:
    Launch Songbird and then connect your player to your computer. Select "Repair" under the "Tools" menu. Follow the instructions given by the pop-up windows to perform the repair process.
    Hope this works.
    Feb 21, 2011 | Philips GoGear ViBE Digital Media Player
    Wmv format is not playing in philips gogear.wat do i do.?
    Download music with a different extension and read the manual of your MP3 and make sure you know what type of format the music needs to be in for you to listen to it.
    Hope this helps ^^. Please dont forget to rate, Thanks
    Mar 03, 2010 | Philips GoGear SA3020/37 MP3 Player
    Philips SA1356/97 1GB mp3 player
    hi my mp3 is philips your problam is same me.help me please my id s.hulangaa_77yahoo.com
    Jan 20, 2010 | Philips GOGEAR SA6045 MP3 Player
    Gogear 1gb-player problem, player connect to pc, player format. It cannot be done formar because it cannot be opened on PC
    Use the player to do the format. If you use the computer's operating system to format the Gogear you may delete critical files for the device or change the file system so the device cannot communicate with it's memory. If you are having difficulty communicating with the device it could be a driver or software issue. Make sure the device's drivers are installed and up to date. Make sure you have the proper software for the device installed. You could also try and update the firmaware of the device. These updates will be available from the Phillips website.
    Sep 23, 2009 | Philips SA5125/37 MP3 Player
    My mp3 player has been formatted
    I have the same problem. I have accidentally delete/formated my mp3 player (gogear sa28xx). But i connected to computer, and i tried to repair it, but after an half an hour, nothing... can you help me? Or if you have the files.. Cheers. Paul
    Aug 26, 2009 | Philips GoGear SA2825/37 MP3 Player
    Message showing - player problem connect pc and fformat player
    i have philips gogear sa 1356/97 mp3 player.it is not working .when i switch on the player a message displays "Player Problem-Connect to pc-format player". My PC not detecting the device.
    Jan 19, 2009 | Philips GoGear SA1350 MP3 Player
    Philips GoGear SA1335 (1GB)
    i have format my player.... because it has virus... after formatting it stopped playing song..... so please tell me what to do?
    Nov 12, 2007 | Audio Players & Recorders
    Philips SA5125/37 MP3 Player Logo
    55 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
