Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
Will not turn on
I have a 52 inch toshiba dlp when I turn it on it will not show a picture and within 3- 8 seconds I hear a siren like noise and the tv powers off.
  • 4,234 Answers
The sound is the lamp that is failing to fire. This could be the lamp or the "ballast". If the lamp is an older one, change the lamp. There sometimes is an indication of the problem via the front LEDs as well. Do any of the LEDs blink? The owner's manual will contain the list of the error codes. If you don't have the manual, post the LED indicators here and we will decode them for you.
Keep us posted.
Dan
Posted on Nov 11, 2008
How to program new remote to alarm
TRANSMITTER PROGRAMMING Note: System can learn up to 3 different codes max. 1. Turn Ignition ON and OFF 3 times quickly, leaving it ON the 3 rd time. (ON/OFF, ON/OFF, ON) You should hear (1) short chirp. 2. Push the Program/Override Button for 5 seconds until the siren chirps (3) times. Release the button. The system is now in programming mode. 3. Press Button #1 on new transmitter - siren will chirp to confirm programming. Repeat Step 3 within 5 sec. for up to 2 additional transmitters. 4. Turn off Ignition. Note 1: If only one transmitter is being programmed, continue pressing button #1 until dash LED flashes goes out and the system chirps to exit programming mode to prevent unauthorized codes and noise from entering the system. Note 2: Programming mode is exited automatically after 5 seconds of last code transmission or once 3 new codes have been programmed. The LED will flash (4) times indicating program mode exit.
Jan 12, 2011 | 1Way Remote Transmitter
I have a toshiba 62HM95 DLR TV. I was advised by Toshiba that I needed to replace the lamp to correct my issue. However the replacement lamp worked for 1 evening and I am now back to my original issue. ...
This could be a sign of the color wheel failing. This is part of the light engine assembly and is not sold separately as far as I know. My most common source lists the light engine as out of stock. (The last quote I had was ~$600 for the assembly.)
The cooling fans can also cause a noise as they fail. However, the red light would be blinking in that case.
I hope this helps.
Sep 01, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
When i turn on my tv it make a winding siren noise but no picture, i replaced the lamp, would it be the colorwheel?
sounds like the color wheel as it can almost sound like a whirling siren or a loud screeching sound
Jul 20, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Hdtv dlp 52 inch loss of picture and loud buzzing noise
Please see http://www.fixya.com/support/t1011937-transformers. It sounds like your flyback transformer is not properly soldered down/is failing.
Sep 06, 2008 | RCA HD52W59 HDTV Projection Television
Flickering and freezing of picture for a split second
The most likely problem for image problems and flickering is the lamp (23311083A). I found it at PartStore.com for about $180. Hope this helps.
Nov 11, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 46HM84 DLP Black and white pattern..
contact your dealer for service flashfor this symptom.(light tunnel)
Aug 11, 2007 | Toshiba 46H84 46" Rear Projection...
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
219 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
