Question about Philips 9P5544C 55" Rear Projection Television
Tv is on as bright at it will go, and the pictures are still too dark
I have the tv on as bright as it will go and it is still too dark, especially with nightime scenes. What could be causing this and how can I fix it. I have had the tv for about 8-10 years. Everything else is great.
    Genius:
  • 1,153 Answers
You can open the back and look for the focus block, this block has 6 knobs on it. 3 are for focus and 3 are for screen control. You will need to turn up the 3 screen control at slightly the same rate. If you are off balance you will have color problems, Do not turn up too high. Becareful, cause you will need set on to adjust. Do not touch anything else. If you move the focus by mistake then you will have to readjust. 3 Guns you will have to adjust one at a time, by covering the other two. Hope this helps!
Posted on Sep 24, 2007
  • Lashawn Robinson Sep 25, 2007
    You can also look for a leaky capacitor in the 200v line around the flyback.
    New Friend:
Replace lite bulb
Posted on Jan 22, 2013
SONY KLV32S400A - picture has become dark, faces on screen cannot be seen
Check the voltages that comes to the back light inverter, especially, the voltage from the main digital board that controls the brightness. If is found OK, be sure that the backlight inverter board is faulty. If not, the main baord. If you wish to get some details, check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 13, 2013 | Sony KLV32S400A 32 in. LCD TV
Bad picture
Sounds like the DLP chip has failed. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 14, 2018 | BenQ Televison & Video
Hi Guys, I have a JVC 32T55EKS TV & the picture is overly dark. When the picture goes through the set-top box the picture gets even darker. The brightness is turned up fully & I have accessed the...
U turn on the contrast level to the max,if still not watchable,tv cathoray tube is dying,radiaton is disappearing.Time to buy another tv.
Feb 14, 2011 | JVC AV-27230 27" TV
Picture is very dark on all channels. Settings have not changed. Do I need to replace the bulb?
You may need a drive PCB. This PCB can cause the picture to be too bright, no brightness or picture too dark, intermittantly or permanantly. Do check the bulb though and see if it is foggy looking or dull especially if it has not been changed. Thanks for using Fixya.
Oct 27, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
My 61" hitachi rear proj has a very dark picture.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image.
How old is this TV and did you replaced its Lamp recently?
If lamp has not been replaced yet or in last 2-3 years, replace it.
Oct 13, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
The Contrast and Brightness on tv appears to be dark.
If this is a CRT-based TV and it's been played most of the time, you may have a bad picture tube, especially if strong red colors bleed to the right. CRT's dim with use, unlike LCD or plasma. But it could also be trouble in the video circuits - none of this falls into the DIY category, unfortunately. High voltage involved, unless you're comfortable around it and want to try turning up the screen controls inside the TV. If you do, let me know - but "no response at all" from the external adjustments points to a more serious problem.
Dec 10, 2008 | Toshiba 36AF41 36" TV
Picture is too dark
How many years is your TV now? Usually TV has its life span, there comes a time that it happens. And need to look for a technicians, cause some of theme can still be repair by adjusting the brightness inside your TV.
Oct 19, 2008 | JVC AV-27530 27" TV
Picture goes dark
1 your problem is in video section 2 if it is ok then check power supply for any components defective.
Sep 15, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Philips 9P5544C 55" Rear Projection Television Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
