Question about Dell A940 All-In-One InkJet Printer
Problems with dell all-in-one 920 printer
The power light keeps flashing when printer is power up. If cartridge compartment is open cartridges does not move to access point.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
1. turn off the printer
2. remove power cable.
3. move ink cartridges to center manually
4. clean the metallic rod with kleenex or WD40 if required
5. Make sure that lids are properly snapped in for ink cartridges.
6. Connect power cable and try again to print
let me know if that works
Posted on Nov 11, 2008
Light keeps flashing
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Mar 28, 2012 | Lexmark Z611 InkJet Photo Printer
It won't print and the light keeps flashing. I lost the instructions!
Feb 13, 2012 | Lexmark X1240 All-In-One InkJet Printer
Blue light keeps flashing on on switch
Dec 29, 2011 | Lexmark Z735 InkJet Printer
Hi im having some problems my aunt just gave me her lexmark 1250 and the paper keeps jamming i think i have that fixed but now i go to print a test page to see if its working and all i get is a flashing...
The flashing power light could be to a faulty cartridge or the cartridge carrier has stalled. Follow the steps below to fix the problem:
  1. Open the printer cover.
  2. Ensure there is no jammed paper in the cartridge area and the cartridge carrier is free from any obstructions (any foreign objects or debris)
  3. Remove both cartridges from the printer.
  5. Unplug and replug the printer into the power source to reset it.
  6. When the printer turns on, re-insert 1 cartridge first. Close the printer cover.
  7. Check the light pattern on the power. If not blinking, open the printer cover and re-insert the other cartridge.
  8. Replace whichever cartridge is causing the power light to blink.
Hope this information has been helpful.
Jul 28, 2011 | Lexmark X1270 All-In-One InkJet Printer
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
Just changed ink and printer does not respond at all. I have a Dell 920 Thanks Shelly
Shelly,
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 31, 2009 | Dell Office Equipment & Supplies
I just refilled my HP6500 ink cartridge 920. The ink level indicator still shows a low level of ink. How do I reset the ink indicator.
There is no way to reset the ink levels on this cartridge type yet. Any replacement chips on the internet are violating patent law. Once the chip tells the printer it is empty it will not print no matter how much ink is left in it. There is always a lag time between the introduction of a new cartridge type and the ability to fill it properly. For refills I would recommend Cartridge World when this cartridge type can be refilled.
Nov 01, 2009 | HP Officejet 6500 Wireless All-in-One...
LSU erorr appear in display screen
LSU refers to the long strip of glass / encoder strip inside the top of the cartridge compartment. It could be dirty or dislodged.
Power off the printer
Open the front cover
Lightly pull out the cartridge and keep it flat
Gently swab the LSU. If part of the LSU is hanging, gently put it back in place and reconnect. Be careful not to touch anything else.
Note: If you are unable to reconnect the LSU, the printer will need service.
Put the cartridge back (again, leave it flat).
Close the front cover.
Power the printer back on.
Hope this helps.
Jul 28, 2009 | Dell 1600n All-In-One Laser Printer
Flashing Green Light/ Computer can't communicate with printer......
Hi. The flashing code signifies that there is a fault with the connection between the ink cartridge and the printer - usually because either the tape is still on the cartridge or maybe some glue from the tape still on the contacts. In my case, I think the cartridge was simply knackered, so I threw it away and opened yet another ink cartridge. It now works fine.
If you want to test yours, simply take out both ink cartridges, and re-insert them one at a time. If you've put a working cartridge in the flashing will stop; if you've put the dodgy one in it'll still flash. Just replace the dodgy one.
Hope this helps.
Dec 14, 2006 | Dell A920 InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
144 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
