Acoustic solutions 513 3848
My mp3 keeps on freezing nd i cant get it to work- the batteries are new any idea what might be causing this problem?
KEV TECH
  • 3 Answers
SOURCE: Acoustic Solutions DVD600k DVD
View the back of the remote for screws. Remove the batteries and make sure there's no screw there too. The top of the remote is clipped to the bottom. Use something flat to prise it open, and thoroughly wipe the surface of the board that comes into contact with the keypad, using a clean cotton cloth dipped in methylated spirits. Wipe also, the keypad. Give some time to dry and reassemble.
kev tech.
Posted on Jun 05, 2008
  • 13433 Answers
SOURCE: mp3 player not working properly,
try another pc for a start
Posted on Jun 09, 2008
SOURCE: acoustic solutions mp3
Hi
If it's an IPOD I found this solution http://www.apple.com/support/ipod/five_rs/nano3gen/#
This was the procedure for my 3rd generation NANO.
Step 1 has never worked for me but the reset has worked so far.
Hope this helps
Ann Mckay
Reset To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Posted on Sep 16, 2008
SOURCE: Sky plus remote code for Acoustic Solutions TV
The code is 065 pal.
Posted on Dec 09, 2008
rockitman187
  • 2559 Answers
SOURCE: lost disk to install my acoustic solution mp3
Try this,put it in MSC mode,Plug into your computer,open My Computer,(The player will show as a drive)Open up the player,open the folders and delete what you want deleted.Then when you want to add more songs,Open it the same way as above and drag and drop them.You do NOT need to use a media player to load or remove items.And Please rate this solution.
Posted on Jan 14, 2009
My tv is keep turning itself on and off and my remote has randomly stopped working, ive had the plug out the wall the past 6 hours nd no joy, any ideas? I've put new batteries in the remote 2
Sounds like a power board issue? Dry joints on the main board? Capacitors may have issues.? I would not go opening up the TV if you are not aware of the potential dangers.
Mar 25, 2015 | Luxor LE40WTUD-B 40 Plasma/LCD/TV Cart
Ive just purchased a acoustic solutions sp132 usb turntable to convert vynil record to mp3 via computer. no instructions at all, cant get it to work
I HAVE AN SP132 ACOUSTIC SOLUTION TURNTABLE USB BUT I CAN'T GET NO SOUND I HAVE PLUGGED IN THE MAIN AND CONNECTED THE USB BUT CAN'T HEAR ANYTHING THROUGH MY SPEAKERS CAN YOU HELP
Dec 31, 2009 | Audio Players & Recorders
My Rio carbon keeps freezing up
Your internal microdrive is probably playing up. You can either get a new microdrive (can be found in old ipods) or a CF card (sandisk CF ultraII work) or buy a new one.
Mowcius
Nov 27, 2009 | Rio Carbon MP3 Player
Mobile got hung up
pls flash u r mobile once and proble will solve
Nov 19, 2008 | Nokia 2600
Acoustic solutions mp3
Hi
Hope this helps
Ann Mckay
    Tip:
Sep 02, 2008 | Audio Players & Recorders
Ipodclassic
keep press on menu and center for 6 or 8 seconds
Aug 21, 2008 | Apple iPod classic MP3 Player
Freezing up
grr someone better come up with a solution soon mines the same !just let the battery die
Jul 15, 2008 | Creative Labs ZEN V Plus MP3 Player
Samsung sgh-e370 phone freezed
switch it on and than press *2767*2878# it will reboot and ur problem will be solved
Apr 24, 2008 | Samsung SGH-E370 Cellular Phone
199 people viewed this question
 Grubhead
Grubhead
