This Modem (HDAudio SoftV92 Data fax modem with SmartCP) came with my PC and have set it up to send & receive faxes after my stand alone machine broke down. It is good enough when it works but most, if not all, times it fails to receive a fax until I close down all progams I am working on and reboot the PC. As I am not a technical person, it would be really helpful if someone can explain why this could happen and whether it is possible to 'fix' it? I run CCTV cameras off this PC also so can there be a conflict ? I have Norton installed also.
Thank you for Help Pankaj_dic. I have amended the setting on firewall to 'allow' instead of 'custom' (is that what you meant?) and hope that it works. Thank you for Help Pankaj_dic. I have amended the setting on firewall to 'allow' instead of 'custom' (is that what you meant?) and hope that it works.
You can't post conmments that contain an email address.
That PCI soft V92 modem is from 2005 - what version of Windows are you using? Have you checked that is suitable for HP 1400 printer? If so, I would officially un-install yout Epson printer, re-boot and re-install your HP 1400
Your modem setting probably is not compabile with the data rate your phone will support.
From the user manual --
If you are having difficulty sending or receiving a fax due to possible interference on the phone line, we recommend that you adjust the compatibility setting to reduce the modem speed for fax operation
Press a or b to choose Basic or Normal (or High). Basic cuts the modem speed to 9600 bps. Unless interference is a recurring problem on your phone line, you may prefer to use it only when needed. Normal sets the modem speed at 14400 bps. High sets the modem speed at 33600 bps. Press OK. Press Stop/Exit.
The other thing to consider is do you have tone or pulse dial service from your telephone company?
your computer has to be set to answer the phone so it receives the data and sends it to your printer. unless the data is demodulated via the modem or other demodulating softwarew .. it cannot be printed and or viewed. check your settings in the "printers and faxes area of the control panel to verify proper settings or make any necessary changes.
Audio Driver for dv2000:
The audio installation involves two steps. First you need to install
Microsoft Universal Audio Architecture (UAA) Bus Driver for High
Definition Audio and then instal Conexant High Definition Audio Driver.
Both can be downloaded from the following links:
Please make sure that you install the drivers in the same order as it's mentioned in the post to avoid any problems.
Windows XP Device Drivers for dv2000(for AMD Processors):
nVidia nForce Chipset Driver: Install the nVidia Chipset Device software from the following link: nVidia Chipset Device Software
An RJ22 connector is the same one as you use on your phone. I would say you have a modem card in there. It simply connects to a special plug inside your computer.Perhaps the one built into your motherboard is defective ,or, cannot do faxes.Back in the day when modems were the primary method to connect to the internet, some systems used two modems,one to receive data and one to transmit data since it made the internet connection faster. That may be why you have two. If you want to use it to get on the internet, simply plug your phone line into it.Plug it into the right connector though. Most have a second connection that allows you to plug your phone in as well.It will have a little phone stamped into the steel above the connector.Using it for a fax modem may require special fax software so keep that in mind.
