Question about Honeywell Heating & Cooling
Why does my T V R Leak ?. - Honeywell Heating & Cooling
Did not request an air conditioning system ?
Thanks
R V Chadwick
Posted on Nov 13, 2008
What else can cause this leak
there is a plunger inside them takes o rings too
May 02, 2015 | Refrigerators
What is a P2404 code mean from a suzuki sx4
Trouble Code: P2404 (2.0L L4 VIN 5 Automatic CVT)
Evaporative Emission System Leak Detection Pump Sense Circuit Range / Performance
Number of Trips to Set Code: 1
Trouble Code Conditions:
EVAP vent valve stuck open: EVAP leak check pressure is lower than -0.14 kPa even if EVAP vent valve is operated from OFF (OPEN) to ON (CLOSE) with EVAP leak detection pump ON. EVAP vent valve stuck closed: EVAP leak check pressure is unstable (difference between maximum and minimum is 0.36 kPa or more) when EVAP vent valve is OFF (OPEN) with EVAP leak detection pump ON. EVAP leak detection pump stuck OFF: EVAP leak check pressure is higher than -0.14 kPa even if EVAP leak detection pump is ON. EVAP leak detection pump flow high: Reference pressure of EVAP leak check pressure is lower than specified value (depending on BARO) EVAP leak detection pump flow Low: Reference pressure of EVAP leak check pressure is higher than specified value (depending on BARO).
Possible Causes:
  • EVAP leak detection pump (in EVAP leak check module) and/or its circuit
  • EVAP vent valve (in EVAP leak check module) and/or its circuit
  • EVAP leak check module and/or its circuit
  • ECM
Jul 11, 2014 | 2010 Suzuki SX4
How can I find the water leak in my Great Lakes Spa
turn system off let water settle get pheno red or leak detector squirt carefully by each spa jet if color goes to that area it could be leak i need more info was this spa winterized if so take sides off look for the water you might have to dig the insulation away to acually find leak usually it is plastic couplers
Jun 07, 2014 | Jacuzzi Balboa R574 System for 1 2 Speed...
Undefind Freon leak
that is a very fast leak. try using UV dye leak detector. color of this dye is bright green and will be show at the leak source. a UV light is also helpful so you can see it better. you can buy this at any auto parts with freon mixed with it, with this leak you should see oily trace at the leak area, don't forget to recharge compressor oil after your repair.
Nov 06, 2013 | 2007 Chevrolet Uplander LS Minivan
Power steering pulley has a leak should i just change pulley?
the pulley does not "leak" the power steering pump however will leak. If there is a leak near the pulley than I would suspect the pump is the source of the leak.
Apr 11, 2013 | Jeep Cherokee Cars & Trucks
I got codes p0455,p1421,p1423,p0141
code P0455......... Evaporative emission system leak detected ( large leak ) check gas cap
code 1451...........secondary air system leak ( bank 2 ) check for vacuum leak
code 1423...........secondary air system leak ( bank 1 ) check for vacuum leak
code 0141...........02 sensor heater circuit ( bank 1, sensor 2 ) replace 02 sensor
Mar 02, 2011 | 1997 BMW 328
How do i fix a freezer that has an internal leak
you need to perform a leak search to determine where the leak is.
If the leak is external to the cabinet, then you can repair the leak. If the leak is found to be within the walls of the unit, the leak cannot be repaired and its nothing more than scrap metal at that point.
Jun 06, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
I have a 2003 dodge ram 1500 with a V-8 4.7 engine and my check engine light came on with a P0456 code and I have been told that it could be the gas cap, I have checked it and it seems fine but should I...
The leak in your evap system is very small at .020. It is more than likely a small split in a hose somewhere. The cap is probably ok, we rarely find a bad one. If it is a small split in a hose it will only get larger over time. Here is the factory info on the code. We have found that alot of these leaks are from a small hose on the evap canister under the vehicle, but with out looking at your vehicle it is hard to say. If the leak goes away or is no longer large enough to be detected, your light will go out after a few days. These leaks are emmissions related and will not effect the integrity of the vehicle. I would have it checked and corrected if the light stays on at your convienience.
Symptom List:
P0442-EVAP LEAK MONITOR MEDIUM (0.040) LEAK DETECTED
P0455-EVAP LEAK MONITOR LARGE LEAK DETECTED
P0456-EVAP LEAK MONITOR SMALL (.020) LEAK DETECTED
Test Note: All symptoms listed above are diagnosed using the same tests.
The title for the tests will be P0442-EVAP LEAK MONITOR
MEDIUM (0.040) LEAK DETECTED.
When Monitored and Set Condition:
When Monitored: Immediately after a cold start, with battery/ambient temperature
between 40° F and 90° F and coolant temperature within 10° F of battery/ambient.
Set Condition: If there is a leak larger than 0.0409 and smaller than 0.0809 in the
evaporative system.
Set Condition: There is a leak larger than 0.0809 in the evaporative system.
Set Condition: There is a leak larger than 0.0209 and smaller than 0.0409 in the
evaporative system.
POSSIBLE CAUSES
LEAK AT GAS CAP
VEHICLE HISTORY AND SERVICE BULLETIN INVESTIGATION
VISUAL AND PHYSICAL INSPECTION
VERIFY EVAPORATIVE EMISSION SYSTEM LEAK
EVAP PURGE SOLENOID OPERATION
INTERMITTENT LDP MONITOR FAILURE
EVAPORATIVE EMISSION LEAK DETECTION
GAS CAP
LDP COMPONENT LEAK
Jun 12, 2009 | 2003 Dodge Ram Maxi
Freon Leak 1992 lexus ls 400
there is no common place to check for leak on this car. but i have done alot of evaps in dash.
the compressors.lines.and condensors will all leak sooner or later. the best way to find your leak is to install dye and recharge system and look for leak in a few days with uv light and glasses.you will find the leak. sometimes if leak is bad enough on the evap. you can see it coming out of the drain hole oh fire wall.
Apr 02, 2009 | 1992 Lexus Ls 400
Fuel leak
If you see the leak when you start the vehicle then you know where the leak originates from. You need to address the leak and find the solution to stop the leak. The leak does not go away. The extra heat just evaporates the fuel faster than it is leaking. This may make you think it stops when actually it has not.
Mar 12, 2009 | 1985 Ford LTD
Heating & Cooling Logo
42 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
