Back to:
Tags:
Rainbow E series Canister Wet/Dry Vacuum
Rainbow shotting water out (by 2 users)
posted by Meishu on Nov 06, 2006
Is there a way I can get into this vacuum so I can see why it is shooting water out? I cannot remove the aerator peice inside that says it should be cleaner after each use. The screw seems frozen, I removed the 3 screws from the bottom and can't seem to see what is holding it together- can't get the bottom off. Any suggestions?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by kkdreams, posted on Jan 28, 2008
I just replaced the hepa filter in my eSeries and pretty sure I have all back together correctly, but now have water blowing out the back of the vacuum. (Other than dirty filter it has been working fine.)
Any suggestions?
Best Solution
posted on Oct 04, 2007
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Are you filling the water pan too full? Check that the separater spins on the shaft freely too.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Rainbow shotting water out:
I don't want to Accept this solution
Solution #2
posted on Jun 24, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
UNDERNEATH THE VAC THERE IS A LITTLE TOOL THAT HELPS GET THE SEPERATOR OFF ITS STORED TO THE RIGHT OF THE SEPERATOR LOOKS LIKE A PLASTIC CIRCLE i ALMOST DIDN'T FIND IT.
Thank You!
Solution #3
posted on Mar 12, 2008
Not Rated (0)
my4boyz
Rating: 0%, 0 votes
My 4 year old tipped my e series on its side while it was turned off and had water in it, and now it is shooting water from the back filter. I bought a new filter, but it hasn't gotten here yet. I am affraid to turn it on even when I get the filter because there might be water in the motor. The seperater is not cracked and seems to be fine, so is it possible for the water to get to the motor by tipping it over? If so is there a way to remove the water.
Thank You!
Can you Help with these Vacuums problems?
Once in a while it will make a real faint noise the...
the silver disks or fans how do they go back together
the power nozzel or main unit of the rainbow e series has...
whenever i try to dispense water out of my wet vac the...
was just using it today and turned it off for a moment and...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
