Question about HP Compaq nx6110 Notebook
My pc do not use the travel battery 52wHr
When battery #1 goes dead, battery #2 is supose to take over.
They are bothe fully charged ad the time seem to bee about 6 - 7 hours.
When #1 goes to 0% the time disapere and the the procent cahange to 55%, but a minut later the pc die.
The two batterys are the right ones for each other.
Please help
  • Teis Thomsen
    Teis Thomsen Nov 11, 2008
    I dident by a secondhand battery, and the travelbattery is fully charged when #1 go flat and the computer die.
    When I charge it again, I can see that #2 still is at 100%.
    /Teis
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 77 Answers
Maybe you buy a second-hand cells Compaq NX6100 notebook battery. The battery usually out of work in 40%. I found many cheap used batteries in ebay. or you
Posted on Nov 11, 2008
My kindle fire does not keep its charge. I can use it one time and during the ap it goes dead
If you charge the device fully, meaning 100%, and while using it with a simple app it doesn't last 2 hrs. then you need to replace the battery. Next time it goes dead, don't turn it on, instead plug the charger and let it charge to 100% while the device is off. Once is fully charge, use it as you would normally do. But still,it needs a new battery.
Apr 30, 2015 | Tablets & eReaders
G'Day.. I have a Plega Traveller, (it no longer
Sounds like one or both of the batteries has a high internal resistance. Bad batteries, perhaps? Have you LOAD tested or tested for internal resistance? Could be why charger is shutting off so soon.
Voltage isn't the only test for these types of batteries.
Oct 24, 2013 | Health & Beauty
Charging problem the red light and green light or both on when charging and the batteries don't seem to be charging
sounds like the batteries are dud, most chargers have 2 or 3 lights, red (max charging) Amber (battery nearing full charge) Green (fully charged and most will switch to a trickle charge) has the scooter been out of use for some time as scooter / wheelchair batteries must be kept charged, and only a short time of no use can destroy the batteries.
Sep 09, 2013 | Golden Technologies Companion II Travel...
Battery won't fully charge. Max charge seems to be slowly going down. First noticed charging light coming on intermittently but battery only reached about 93%. 4 days later and the max charging seems to...
It seems that the issues is with the battery itself, not the cppu.
To double check, you can do the following:
1. Disconnect adapter and run battery completely dead.
2. Reconnect adapter and let charge for at leasst 12 hours OR until battery displays 100% charge.
If it still won't charge to 100%, then you know for sure the battery is defective/worn out..
If you want to know more about this, look on wikipedia for: "Laptop Battery Lifespan" or "Laptop Battery Memory Charging".
But I'd say it's safe to assume that it's time for a new replacement battery for your Notebook PC.
Hope this helps!
Apr 14, 2011 | Gateway E-475M Notebook
What i do when the nokia1600 set is fully dead due to unknown factors?
1. Try recharging the battery.
2. Even after charging the battery for sufficient amount of time, your cell phone goes off in few minutes, you will need to change the battery.
May 15, 2010 | Nokia 6030 Cellular Phone
When I turn my computer on, the screen flickers and then goes black.
1. Check you batteries to see if it is fully charged.
2. Then check the power adapter to see if you are getting a charge to the battery.
3. It sounds like the battery is not charge or has a dead cell in it.
Apr 27, 2010 | Toshiba Satellite A205-S4797 Notebook
Battery losing charge whilst plugged in to cig lighter
I have the same problem, when the battery goes dead, it seems to do so instantly vs. just holding the charge for less time. You can replace the battery, but with the prices coming down and the fact that the map upgrades cost what they do, I'm thinking it's more cost effective to just buy a new GPS.
Apr 18, 2010 | Tomtom ONE 3rd Edition GPS
My MPC t2300 laptop wom't turn on.
The Transport T2300 has an internal battery that will run the laptop for several minutes after the main battery goes dead. This feature allows you to save your work and shut down safely. If you run the laptop until both batteries are dead, even a brand new battery can't start the unit again. You have to follow this procedure:
1.Unplug power cord
2. Remove any attached periphal components including the cd rom and/or floppy disk module if you have one. Both remove with a push button switch located on the bottom of the unit.
3. Plug in power cord and charge the unit for a minimum of 24 hours straight. 30 hours is better. This whole time will be spent slowly recharging the internal back up battery.
4. Once that is done, unplug power cord again and reinstall any floppy/cd drives. Plug power cord back in now and charge for at least 24 hours again.
If your backup battery is dead, you can't charge the main battery or turn the unit on. The longer you charge, the better. We had one unit here that had to be on the initial battery backup for 72 hours before it finally took hold. Then, one overnight recharge on the regular battery and all was well.
If you need drivers or manuals for the 2300, all are available on cd at mpcsupport@cox.net for around $9.50 including shipping, handling, and owners manual
Apr 11, 2009 | MPC Computers TransPort T2300 Notebook
When I charge my iPod Nano it charges fine but instead of turning off or ... it will turn off but in about 2 seconds it goes to the "Charged"
You need a new battery for your iPod. you can view a free instructional video on battery replacement at the first web address posted below. the second one is a cheap site I found for purchasing iPod parts.
http://fixyouripod.weebly.com/
http://www.ifixit.com/
Mar 13, 2009 | Apple iPod nano
Phone loses connection after few minutes
I looked up the battery specs for your phone. They are 3 X 200mah= 600mah battery packs. They should last 8 hrs talk time with the headsets. This style of battery pack in my experience only last about 1 1/2years and sometimes longer and "sometimes" shorter...much shorter. I bet you never had problems when you first got them. Basicly this "battery design arrangment" goes back many years before newer battery technlogy was developed. But designers still insist on using them even today. They are cheap to make. ****Time to replace them with new ones.**** Make sure you follow the mfgs charging instructions: "After battery installation, place the handsets in their base unit or charger and allow to charge for 16 hours before use. You can keep the battery charged by returning the handsets to their base unit or charger after each use. When the battery is fully depleted, a recharge takes about 12 hours. Average talk time on a fully charged battery is about eight hours depending on environmental conditions, standby time is approximately four days." Good luck
Jul 19, 2007 | AT&T E5640 Phone
HP Compaq nx6110 Notebook Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
