Question about Samsung 1.8 Cu. Ft. Over-the-Range Microwave
My Delonghi (DMX65) microwave oven convention does not heat up
Firstly,pls, assist to get its manual ans secondly when the mcrowave or grilling buttons are pressed,it does not heat up except when the convention button is pressed.
MicrowaveSvc
  • 9086 Answers
SOURCE: DeLonghi combined microwave/grill/oven.
Found this posted in GE instead of DeLonghi but the basics are the same.
You say it stopped working - you mean it runs but doesn't heat?
Posted on Nov 22, 2007
  • 86 Answers
SOURCE: Where is the 10 amp fuse on my delonghi micro/combo/grill please
Hi, I take it that this is a combi microwave? Some of these have settings on the front to microwave/grill/etc... so make sure its on the right one first!!
If you have selected the correct one then the m/wave does not work it could be several things!
Microwaves run to earth and need diodes to do this if these break down it will not m/wave! It could also be a internal fuse? ( but very unlikley if everything else works) Then you have the Mag or transformer which could be down to! M/waves run on a high power side and a low power side. The low power will not hurt you to much but the high power side will. My advice to uou is not to touch as it could be fatal as these things carry a high charge even when they are unplugged!
Posted on Dec 28, 2008
SOURCE: My Delonghi mcrowave turntable is not
Thank you for your eMail.The problem seems to sort itself out through luck more than anything else!I have made a note of your address for future reference.Thanks again.
Posted on May 13, 2009
  • 197 Answers
SOURCE: microwave not working
Magnetron may have died or internal fuse may have blown.Its could be all sorts of things.
May be time to buy a new one!
DO NOT TAKE OFF THE COVER YOUR SELVES, AS THEY MAY BE ELETRIC CHARGE STILL PRESANT EVEN WITH THE PLUG DISSCONNECTED
Posted on Sep 18, 2009
Testimonial: "Quite helpful; all I have to do now is translate the two solutions into french to ask them to check. Buying electrical in France is very expensive."
  • 8 Answers
SOURCE: Switching off the sound of my Samsung Microwave
1 Press the Sound button. The display shows "ON".
("START" will flash)
2 Press the Sound button to turn the volume off. The display shows:
"OFF".("START" will flash)
3 Press Start. The display returns to the time of day.
Lastly, you can find a copy of the manual here:
http://downloadcenter.samsung.com/content/UM/200507/20050727140356453_DE68-01945A[GB].pdf
Posted on Nov 11, 2009
I need a instruction manual for a Delonnghi touch control microwave oven with grill model No.DMX 30
http://www.delonghi.com/en-gb/customer-experience/instruction-manuals
either go here and use the product code bar on the label on the back
or send an email to the customer support
they will email you the manual
i cant see it onlne...
Dec 10, 2014 | DeLonghi Microwave Ovens
Mircowave works but doesn't work for heat/grill defrost etc
1.check fuse
2.check relay (microwave oven magnetron)
3, check switches of the doors
May 11, 2014 | DeLonghi P90D23EL-B1A Easi-Tronic Solo...
My delonghi ac925chs combination oven and grill work... microwave has stopped heating have noticed there is no light on in the microwave.and when i went to use it yesterday it would not heat in the...
Check this video it goes through checking and replacing magnetron, capacitor, diode and fuse. It will be one of those. Check the safety instructions in the description.
Sep 04, 2011 | DeLonghi Microwave Ovens
How do i fit a new bulb in my microwave model dmx65
All you need is to remove the top panel screws and remove the top panel after disconnecting the power. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
The bulb is located at the top and faces to the inner chamber . You can unscrew from the holder and replace with the same type and wattage.
Aug 22, 2011 | DeLonghi Microwave Ovens
My de longhi ac925chs has suddenly stopped heating or defrosting but making all the right noises. The oven and grill still work ok. Is this just the fuse and if so, can i change it myself?
It's most likely a burned magnetron, and it's usually as expencive to replace than a new oven but since yours is equiped with a grill and conventional oven check the prices it could be worth changing...
Aug 03, 2011 | DeLonghi MW 535 Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
My Delonghi mcrowave turntable is not turning.Please can you help?Thanks
May 12, 2009 | DeLonghi Microwave Ovens
Dec 28, 2008 | DeLonghi MW 605 Convection/Microwave Oven
I bought a microwave model no:dmx65 but it won't warm the lights came on the time is set but its not heating up what should i do
If it's within the return period for a new purchase, I would take it back.
If not, and it's still under warranty, you'll have to contact the manufacturer to find the nearest authorized service center.
Technically speaking, it may be a bad door switch or switch mount, a problem on the control panel, or in the high voltage parts.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 26, 2008 | DeLonghi Microwave Ovens
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung 1.8 Cu. Ft. Over-the-Range Microwave Logo
158 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
