Question about ASUS P5B-E Motherboard
P5B-E errors after XP re-install
I have a C2D system running on a P5B-E mobo.  The system has run without problems for 18 months with an ethernet connection to another home computer.  Recently I had a problem with the network and after trying many things {icluding updating mobo BIOS} the end result was that I formatted my XP partition and re-installed.
I have installed all the drivers etc from the ASUS mobo support cd as previously but now have two problems:
a.  Whenever I boot up, XP brings up the found new hardware dialogue and asks me to install an unknowm PCI device.  It shows in Device Manager as Other Device/PCI device with an error message and it has been inpossible to find what device the error refers to.
b.  I have two CD drives installed - a DVD RW and CD drive.  No problems before - now the system will only see one of these drives {and I have checked they both work.
The network problem has been resolved but I can see know way to resolve the two new problems other than removing the CMOS battery to clear the BIOS.
Vert grateful for any advice.
John R
  • bukmakers Nov 11, 2008
    i can run the IDE - DVD drive on ASUS P5B-E mother board it dettects it from time to time but when i put some bootable cd it in it ignores the drive like it doesnt exsist and when i restart the drive is not present i the BIOS. Do you know any solution of this porblem, maybe BIOS update or something?
  • 35 Answers
On the issue of cd drivers ,you have to work with the ide cables,try to change or even try new ones
Posted on Nov 11, 2008
LAN driver Freezes Computer
disable the motherboards built-in ethernet adapter in BIOS and get an add-on ethernet card. it sounds like your ethernet card is damaged and its affecting the rest of the computer.
May 22, 2010 | ASUS P5B-E Motherboard
ASUS P5B-E: No Sound after reinstalling XP SP3
THERE IS A SET OF NUMBERS ON THE MOTHERBOARD WHICH ALSO INCLUDES ASUS P5B-E IF YOU GO ON GOOGLE AND ENTER THE MOTHERBOARD NUMBERS YOU SHOULD BE ABLE TO GET THE CORRECT COMPANY & DRIVERS FOR THAT BOARD... GOOD LUCK
Feb 26, 2010 | ASUS P5B-E Motherboard
P5b-e mother board: USB ports on MB stopped working with operating system (have tried win & and XP). All ports work if running op system from disk
I would update the bios, uninstall the drivers for the ports, download the latest, and reboot. If the machine recognizes the ports, it will begin searching for drivers. Interrupt the search and manually install the drivers. If this does not good, I would reinstall the operating system. Also, use the drivers from ASUS...
Jan 03, 2010 | ASUS P5B-E Motherboard
:CMOS Checksum Bad error Hi, My system had intel c2d 2.13ghz processor and 2gb ddr2 ram to begin with. I recently added 2gb more (both are 667 mhz). Now i'm getting an error while booting which says CMOS...
Yes--most probably a memory error.
If you added memory and kept the original memory, they might not be compatible.
Try running with only the old memory.
Then try running with only the new memory.
Bet both work. But not together.
Dec 20, 2009 | ASUS P5B Deluxe/WiFi-AP Motherboard
Foxconn MOBO will not recognize ethernet under Win XP but will under Ubuntu . Have tried installing the drivers available from Foxconns site to no avail. I need to run XP for the software I use. I have...
hmm, have you tried creating a virtual drive in linux to run xp through? if you do this, the virtual operating system (XP) will run in a window while you are running linux, when you are using the virtual operating system (XP) it will piggyback from the linux drivers and use the systems devices. check out the link it will explain it better
http://www.vmware.com/products/player/
Nov 27, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
2 Sata HDD not working at a time
In the bios be sure that all the parameters for the SATA drives/devices are AUTO
Dec 11, 2008 | ASUS Motherboard P5B-SE P965 LGA775 Core2...
Psb-mx/wifi
The problem - I guess - is that this CPU is not recognised correctly by the board. To solve it, just update to the latest BIOS, using either AsusUpdate or manually from www.asus.com
Dec 06, 2008 | ASUS P5B Deluxe/WiFi-AP Motherboard
Sometimes my computer restarts suddenly.
this problem is due overheating, and you say yo have a C2D with this mobo.... at intel site it said that this mobo works fine with intel P4, Pentium Duo an Celeron but not C2D. Its true that you have 800Mhz FSB and it will detect the micropro.... and work fine but the C2D will overheat the mobo for its need of energy and overheat it so it start restarting. I dont know how much that mobo is going to last but start installing all cooler you can....the mission is to cool down that mobo and micro...
Nov 29, 2008 | Intel D101GGC Motherboard
ASUS P5B-MX MoBo Very low sound output.
inthe realteck sound system there u need to adjust the settings in the software set the settings to 2 channel
Oct 24, 2007 | Gigabyte GA-945GM-S2 Motherboard
ASUS P5B-E Motherboard Logo
236 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
