I have a built in Fax modem on my Sony Vaoi and since my stand alone Fax machine broke down, I have been using the PC based software that comes with Microsoft . The problem I am having is that most times I have to re-boot my PC before a fax can come through which is really annoying since I have to keep my PC on at all times for some programs that I use. I can send faxes anytime.
  • smita9 Nov 14, 2008
    Sorry, I should have thanked you earlier but have not had time to look into WinFax Pro as yet - at least I know where to start. Thank you for your help.
    Sergeant:
  • 207 Answers
Smita,
You didn't mention what Operating system you had, Since you mentioned Microsoft I'm assuming it's one of the varieties of windows.
In my honest oppinion I believe your problem lies with using the integrated fax utilities "Built into" Windows. Microsofts Fax utilities never were as good as some of the Standalone software out there.
My best advice if you need to use your PC for faxing is to get one of the stand alone fax programs out there. My recommendation would be WinFax Pro. But you are welcome to shop around and Find one that fits your needs both in cost and functionality.
Good Luck and Take care
Dave
Posted on Nov 11, 2008
I have my machine hooked up with my answering machine. How do I set up to have the answering machine pick up and then once the beeping of a fax starts, it will connect.
Unfortunately you can't do that with any stand-alone answering machines. You'd need to manually activate the Fax when you hear the fax tones. What you can do is use an item like this: http://faxswitch.com/stick.html or this: http://www.usr.com/en/products/telephony-usr4000/ to route the calls to the Fax or the answering machine for you. The other option is to use a TAPI Voice/Fax Modem with your computer that supports telephony operations. Then you can use the computer to answer the fax calls and telephony software to add an answering machine to the computer. (This is one example: http://www.ventafax.com/ .)
I wish that I had better news for you.
(Note: I have a USB Voice/Fax Modem that claimed it would handle telephony operation after a firmware upgrade to the unit. It never learned how to correctly interpret the necessary codes. This may be a driver issue but I never resolved the problem. So my fax modem is still on Manual answer.)
May 12, 2015 | Canon PIXMA MX922 Wireless All-in-One...
Where to plug in the phone line for the fax
You don't plug a phone line into this printer. It's not a fax machine itself. According to the user's guide (which you can download here), "To send a fax using this printer, you need to have the printer attached to a computer that is equipped with a modem and has Microsoft Fax installed."
What this means is that the printer is just serving as the input (scanner) and output (printer) parts of a stand-alone scanner, but you need your computer to connect to the phone line. Without the computer modem and Microsoft Fax software, your printer is, well, just a printer, with scanning capability.
Sorry! Thanks for using Fixya.
Nov 19, 2010 | Dell 944 All-In-One InkJet Printer
Does Windows 7 have the ability to send and
Well Yes, if you have a Modem, You can connect a Modem & then one can get software that you can use as a Fax machine. Also I believe there is a Built In Fax software too. However I recommend a third party setup. There are lots of really good FREEWARE Fax programs. Ensure they work with Win 7.
Feb 05, 2010 | Office Equipment & Supplies
I lost my manual and would like help in connecting to phone jack
Each phone or dial-up modem or fax machine needs a DSL filter attached to the phone line/socket then each phone or dial-up or fax machine is then plugged into this filter.
The DSL modem does not require a filter.
If your fax is part of the computer's modem then a filter is also required on the line-in on the modem.
The instructions for sending & receiving depends upon your system/dial-up modem (the make & model, is it stand alone or a modem adapter on the expansion slot or built-in on the motherboard) and the software you are using. Cannot help you without these details.
Apr 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Sony Vaoi built cam doest work on messenger
i have a gateway fx gameing laptop!! i was having probs with the cam going dark on me after a bit while using yahoo messenger..it was also freezing up but that i found out was cause yahoo SUCKS **** LOL...
i downloaded msn messenger, not msn live, and the cam works fine.. so it is yahoo.. i do know that sometimes my cam will sometimes go darker in resolution if i bend the top down a bit.. its doing that because the cam is thinking that im turning it off by shutting the laptop!
does the web cam work with the software it came with? can u turn it on and see urself when NOT using a messenger? if so then it might just not want to work with those 2 messengers which is weird!!!!!
MAKE SURE THAT U DO NOT HAVE THE PROGRAM SOFTWARE on that came with the laptop at the same time as trying to use it with the messengers!! see if that works and ill check back with you!
laptops did not come with the high end state of the art web cams! they were made for ease not for exceptional quality!
Mar 22, 2009 | Sony VAIO VGN-SZ430N/B Notebook
Have to reboot PC before receiving faxes
check the firewall setting of norton
Nov 11, 2008 | Computers & Internet
Can a Lexmark X4270 be used as a stand alone copier and fax without being hooked to the computer?
Absolutely! The only thing needed for use as a fax is being plugged into a live phone line. These are specifically designed for just that purpose so the computer does not have to be left running while fax machine and copier remain on in the office. Mainly so the office can shut down the computer when not needed to save power when not needed. Ex. to receive faxes at night when the office is closed. You only need to leave the printer on and it will function as a stand alone copier fax machine. The computer is only required when you want to print a document or scan a page and save it. I hope this fully answers your question.
If you have others feel free to ask.
George
Jul 30, 2008 | Computers & Internet
MODEM
Make sure you have followed the instructions for installation first. Most wieless nic require that you install the software first before inserting the modem. It can cause damage to the part when not properly installed. Also check the system specifications that the modem requires. Please comment if this is not the case.
Hope this helps you
Oct 25, 2007 | Sony VAIO VGN-S460 Notebook
Computers & Internet Logo
David Payne
David Payne
