Question about Cisco Catalyst 2924 Networking Switch
Cisco 2801 my cisco can't be used..because port console can't acces...and all led indicator is to repaired it
    New Friend:
  • 50 Answers
What Model Series do you have?
Posted on Nov 12, 2008
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
Cisco 2801 router does not boot
CISCO/Linksys -To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Nov 01, 2012 | Cisco 2801 Router
Fix broken ejector handle
You need to obtain a replacement flash ejector handle first. If you open the router out, you can push the broken ejector handle out with a small flathead screwdriver, it just slides out forward toward the face of the router if you apply a bit of pressure. Then you just slide in the new ejector handle, which is "keyed" on one side. There is also a small metal lever pin that you need to line up with the spring hole when sliding the new ejector handle into place. Once inserted is will snap gently into place and you are done.
<a href="">Sell Used Cisco Equipment</a>
Mar 15, 2012 | Cisco 2801 Router - 2801
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Amber lights on a Cisco switch.
It sounds like you have loops in your topology. Loops will cause the LAN to crawl.
Amber, on a Cisco switch port means that a port has been blocked either as a security violation (if mac-address security is being used) or by spanning-tree protocol which shuts down ports involved in a network loop.
Check all your wiring carefully...especially the fiber-to-ethernet converters. If anybody has a hub or switch under their desk make sure they do not have two ports from that device patched into two ports in your cisco switch.
From Cisco catalyst 3500 user guide:
Solid amber
Port is not forwarding. Port was disabled by management or an address violation or blocked by Spanning-Tree Protocol (STP).
Note After a port is reconfigured, the port status LED can remain amber for up to 30 seconds as STP checks the switch for possible loops.
Nov 02, 2009 | Ortronics (MC62503)
One way audio on NEC ITL 12 button IP Phone at remote site. Main site has IP Phones which are working fine. IP Phone connected to Cisco 3560 24 port poe switch. Switch connected to 2801 router. Point to...
This is likely a config problem on the NEC or a hardware/software issue on the NEC. Do a Wireshark capture on the NIC on both ends. Examine the RTP streams and see if they are intact. You may have to decode the stream from UDP to RTP depending on if it is a peer to peer call or if it is going through the 8100. Plenty of documentation on how to do that at Wireshark's website.
Aug 01, 2009 | NEC Computers & Internet
Cisco catalyst 3500xl (24 port) bad console
It is possible that your console port is configured for a different baud rate. Try to change your baud rate on your hyper terminal going from 115200 down to 2400. If it doesn't work you might have a problem with 232 driver chip that is located on the board next to your console port. You will not be able to find a schematics for this switch, it is not available for the public.
You can send this switch to me. I will glad to fix it for you.
Good luck.
Jul 05, 2008 | Cisco Catalyst 2924-XL Enterprise Edition...
Cisco 2801 router's power supply
Suggest you go to Cisco for two reasons....A) it may not be an off the shelf item you can cross source and they can be different (even within the same external model number) careful or take a look at the supply itself (open sesame). Hope this helps....Tango
Jan 14, 2008 | Cisco 2801 AC PWR SUPP (PWR2801AC) Power...
Cisco Catalyst 2924 Networking Switch Logo
137 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
