Question about HP Compaq nx6110 Notebook
Nx6110 with travel battery 52 wHr
When battery #1 goes dead, battery #2 is supose to take over.
They are bothe fully charged ad the time seem to bee about 6 - 7 hours.
When #1 goes to 0% the time disapere and the the procent cahange to 55%, but a minut later the pc die.
The two batterys are the right ones for each other.
Please help
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Tip
Hi, I would like some help reg, the T-Mobile MDA charging. I got 2 batteries, 1...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Jan 08, 2008 | T-Mobile MDA
My kindle fire does not keep its charge. I can use it one time and during the ap it goes dead
If you charge the device fully, meaning 100%, and while using it with a simple app it doesn't last 2 hrs. then you need to replace the battery. Next time it goes dead, don't turn it on, instead plug the charger and let it charge to 100% while the device is off. Once is fully charge, use it as you would normally do. But still,it needs a new battery.
Apr 30, 2015 | Tablets & eReaders
G'Day.. I have a Plega Traveller, (it no longer
Sounds like one or both of the batteries has a high internal resistance. Bad batteries, perhaps? Have you LOAD tested or tested for internal resistance? Could be why charger is shutting off so soon.
Voltage isn't the only test for these types of batteries.
Oct 24, 2013 | Health & Beauty
Fault finding
maybe the leds are burnt out
Oct 17, 2013 | Health & Beauty
Charging problem the red light and green light or both on when charging and the batteries don't seem to be charging
sounds like the batteries are dud, most chargers have 2 or 3 lights, red (max charging) Amber (battery nearing full charge) Green (fully charged and most will switch to a trickle charge) has the scooter been out of use for some time as scooter / wheelchair batteries must be kept charged, and only a short time of no use can destroy the batteries.
Sep 09, 2013 | Golden Technologies Companion II Travel...
What i do when the nokia1600 set is fully dead due to unknown factors?
1. Try recharging the battery.
2. Even after charging the battery for sufficient amount of time, your cell phone goes off in few minutes, you will need to change the battery.
May 15, 2010 | Nokia 6030 Cellular Phone
My pc do not use the travel battery 52wHr
Maybe you buy a second-hand cells Compaq NX6100 notebook battery. The battery usually out of work in 40%. I found many cheap used batteries in ebay. or you
Nov 11, 2008 | HP Compaq nx6110 Notebook
Dead battery for one unit won't charge at all. voltage -0- both radios and charger work fine. where can I get battery? P/N MN-160001 capacity 950mAh
First put the dead laptop battery in a zip lock.
Then put the zip into refrigeratory and keep it in freezer for 14 - 15 hours.
Afer waitinf for a long time, take the dead laptop battery out of refrigeratory .
Using clean and soft cloth to dry the battery and get the battery to room temperature (about 20° - 25°)
In the end fully charging and discharging the battery for 3 - 4 cycles.
Now you would see that your dead battery holding up charge for 1-2 hours.
See the detail video in metacafe.com
View more info in : http://www.laptops-battery.co.uk/blog/revive-dead-laptop-battery.htm
Sep 13, 2007 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Phone loses connection after few minutes
I looked up the battery specs for your phone. They are 3 X 200mah= 600mah battery packs. They should last 8 hrs talk time with the headsets. This style of battery pack in my experience only last about 1 1/2years and sometimes longer and "sometimes" shorter...much shorter. I bet you never had problems when you first got them. Basicly this "battery design arrangment" goes back many years before newer battery technlogy was developed. But designers still insist on using them even today. They are cheap to make. ****Time to replace them with new ones.**** Make sure you follow the mfgs charging instructions: "After battery installation, place the handsets in their base unit or charger and allow to charge for 16 hours before use. You can keep the battery charged by returning the handsets to their base unit or charger after each use. When the battery is fully depleted, a recharge takes about 12 hours. Average talk time on a fully charged battery is about eight hours depending on environmental conditions, standby time is approximately four days." Good luck
Jul 19, 2007 | AT&T E5640 Phone
HP Compaq nx6110 Notebook Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
