Question about Sony Ericsson W700i Cellular Phone
Phone is not getting started
Yesterday after attending the call my phone get hanged for some time, and keypad is not working. so i takeoff the battery and inserted the battary back. then it worked fine. and after some time again i got another call and after attending the call the phone totally hanged. and i did the same above process. but this time after inserting the battery back the is not getting started. and the screen is blinking with light and not getting started. and i tried with my friends battery also not getting started. what could be the problem for my phone. please give solution for this problem.
  • 83 Answers
OK
Ur Phone have firmware software (Phone OS) Problems.....U should following the given steps.......
1- If ur phone start try to uninstall all application if any and delete some media files(audio and vedio) to free some memmory.
2- If u success to do this Please Master Reset ur phone (Restore Factory Setting) it ask u to give code.....
3- Remember ur phone battery full charged....
4- If all above steps will not help u than u should contact to Sony Ericsion Service centre.
Posted on Nov 11, 2008
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
Feb 10, 2011 | Lucent PARTNER18 Corded Phone
Phone keeps hanging up when making a phone call
hello,this is a factory fault and i will advice you return it to the store of purchase,and they will humbly attend to you.
OR
Secondly,it could be a virus attack on your phone,and this could be fixed by a mobile phone expert,all he needs to do is just to flash the phone with the use of internet to do the flashing.this will automatically put your phone back in it's initial form.
kindly rate this solution if it's helpful,
TAKE CARE.
Apr 16, 2010 | Samsung Jet S8000 Cell Phone
Nortel 7316e: Need to change the auto attendant
To enter viocemail administration, press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Oct 27, 2009 | Nortel T7316E 2-Line Corded Phone
My keypad wont work except for on/off wotn work
may be your keypad might have worn out or your phonse's software might be under problem. try replacing the keypad in your phone and check it out. it it does not work still then remove the user serviceable parts like panels batteries and clean then using a clean damp cotton cloth.be sure the cloth is not much wet to affect the ic's of the phone.it this also does not work get a pro to attend your phone's software problem,
Aug 16, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Can take and make calls but details don't show on my E90
I'm sure you have already tried this, but have you taken the battery out and put it back in again?
If it's still hung, then you can try doing a reset on the PDA section, but this will erase all your data, so be sure that you have it backed up.
Start by doing the phone reset - dial *#7370# from the phone keypad and then enter the security code (which will be 12345 if you have never changed it) - if that doesn't work, then reformat the filesystem in the PDA:
Take the battery out, hold down "*", "3" and the "Green phone" button and while holding them down put the battery back in - wait until it asks you if you want to reformat. Again, this will erase all your data and settings (and also any of the factory pre-installed content in the internal memory).
Jul 01, 2009 | Nokia E90 Cell Phone (Unlocked) - Black
AT&T 964 won't free phone line when incoming caller hangs up
Verizon is right, it's out of their hands. You may have a defective unit or it may be sharing the line with other equipment that is fooling the phone in thinking the call is still there. Or, you may have DSL on the line and it may not be filtered.
You'll have to start by eliminating other devices from the line, fax, computer, credit card machine etc. Now try the auto attendant voice mail. Add those devices back and check each time.
Jun 16, 2009 | AT&T 964 Corded Phone
Nokia 6300 key pad not working
Solution 1.Any time your phones gets wet or by accident the phone falls off in a pool of water the best remedy is to take the batteries off immediately, don't turn the power key on, and wait for 24 hours for the phone to dry out completely.
Solution 2. Alternate solution is go to settings,select call,select anykey answer, this way u won't need the answer key any more,
Solution 3. Change the keypad,go to the nokia service center.
Apr 24, 2009 | Nokia 6300 Cellular Phone
Nokia 6500classic won't switch off
its not the problem with software . It is the problem with your keypad. It has been freezed from inside . Just because of this whenever you put the battery (due to freezing) phone starts itself. pls vote me thankyou
Feb 13, 2009 | Nokia 6500 Classic Cellular Phone
N72 hangs after starting..
does the phone work without the memory card?
Aug 18, 2008 | Nokia N72 Cellular Phone
Moto w30 keypad not working
buy a new phone. your phone is buggered
Jul 03, 2008 | Cell Phones
Sony Ericsson W700i Cellular Phone Logo
117 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
