Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
Fridge was in storage 4months fan work but not freezing.
Stored for 4 months when i finally found a place pick up ge s/s stainless steal refridgerator did not cool stayed at 62 degrees on both sides freezer and fridge...
  • Michael Perez
    Michael Perez Nov 11, 2008
    no ice 62 degrees 60 degrees no colder than that after storage, another ? freezer door has square four prong connector thats connected but found rectangular connector to no where to connect tilted to see under to find matching connect, what i notice square connector and rectangular connector have the same colored wireing two of each , black, aqua blue, red i cant recall disconnecting and its just hanging there on freezer door by hose coupling connect square connect.
    please Help
    Ps took doors off and replaced doors as best i can remember..
  • Michael Perez
    Michael Perez Nov 13, 2008
    micbeth1981 i have had this pluged in nothin freezes just wont get cold .] after staorage
    Genius:
  • 1,122 Answers
Is there ice building up in back of freezer?mike
Posted on Nov 11, 2008
  • 1 more comment
  • MIKE major Nov 12, 2008
    is there any frost built up anywhere in the freezer?????
    the problem is in the freezer,plug it in for 2 or 3 days and see if frost starts building on the back wall,then you know you have a defrost problem,and chage your rating as you have messed up my expert rating-mike
  • MIKE major Nov 13, 2008
    you how need to check the compressor to see if it is running,also when your back there see if you see any oil on any of the copper tubing as i think you have a leak,also check to see if there is a access valve on the comp. to recharge-mike
Fridge not cold
Check your Model # and Ser#. Probably your Motherboard and condenser fan board. No help from GE but file a complaint 1-800-386-1215. Board # GEA Part no. 200D4860G015 is junk and on every piece of internet writings this board is warranty, however, they(GE) go by the ser# of your fridge. $391 to have A&E come out a replace in 5 minutes. I would recomend working locally.
Jul 10, 2010 | GE Profile Stainless Bottom-Freezer...
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
I'm having problems with my Adora fridge. First, the contents in the crispers started freezing. The storage tank behind the drawers seems to be frozen. Now the water won't dispense. Ice is being made...
Your model has a WR60X10132 or 10055112 Damper and Fan that regulates temperatures between the freezer and fresh food compartment. The part has been recently updated. Refrigerator air inlet cover/damper kit with fan motor. Damper and fan assembly has been updated to prevent freezing in the refrigerator.
(The manufacturer has replaced part number wr60x10132 with this item, part number WR49X10091.) (Manufacturer part number WR49X10091 is RepairClinic item number 1055112.)
BRB with photos and locations. Sea Breeeze
Jan 23, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Item in fridge freeze at the bottom, but barely cool at the top
has the cold air circ fan stopped or jammed? this will allow the cold air to drop to the bottom and not circulate.
Mar 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have the same problem .i took apart the inside of
Most/many times this is a clogged up or restricted defrost drain system, but once in a while the drain system has been cleaned and everything appears to be good but you still get ice in the defrost drip tray and such and the drain freezes over. Some manufacture designed kits to help and some home made remedies. http://www.applianceaid.com/defrost_drain_freezes.html
click the link given above
Mar 02, 2009 | GE GTS12BBPLCC Top Freezer Refrigerator
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Dent in easy clean stainless steel fridge door
first off its not "stainless" its clean steal. and yes it does dent very easy! i found the only answer is to replace the panel or buy a new fridge .. i do NOT recommend clean steal to anyone. i have the same problem a very expensive fridge and i already have many dents in it also scratches. the lady "highly recommened this fridge for people who had kids" i guess i should have done my H.W
Apr 28, 2008 | Refrigerators
Ge profile fridge bottom freezing up
found the problem .the compressor is not putting out enough cold to freeze the coils' only half the coils are freezing in the bottom of the fridge. the fan draws it's cold air from these coils and pulls it up to the top of the fridge where it's dispersed into the top half of the fridge' hence the stat never see's that it's cold enough to shut off the switch . in other words if the coils down below were all working a lot more colder air would be pulled up to the top and the stat would then shut off . Solution is to seek a refund from the service tech and buy a new fridge . it's not worth putting a new compressor into this one although it is only 5 years old hope this helps someone who has the same problem
Mar 17, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
128 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
