Question about Philips CDR765 2-Disc CD Recorder
Philips cdr 765
Hi My cdr has started showing no disc after a disc has been loaded does it with any cd you load. Anything i can try or is this a case of buying a new one Cheers tolly
  • leoaugust007 Feb 20, 2009
    When I load a new blank CD the message reads NO or Wrong disc. Memorix disc create this issue but maxell most time work sometimes don"t. Please Help!!!!
I just purchased one from Ebay. It plays fine on both sides. The recorder will recognize CDR's and the display will say recordable media. But, when I attempt to actually record, it won't work. I have another unit exactly like this one and the CD's I have work fine with that unit. I'm guessing this unit's recorder is bad? Any suggestions? Thanks.
Posted on Feb 26, 2008
  • 112 Answers
The playback side is driven as a slave from the recording side.
The 'no disc' issue for the recorder is more likely a failure of the fragile philips CDD3610 laser used in the unit. I can supply parts and service manuals should people need them ( fluffcat1 on ebay )
Posted on Dec 09, 2007
FOR ME, THE PROBLEM IS THE CD-R DISC. I STILL HAVE A LOT OF AUDIO CD-R BLANKS THAT I BOUGHT IN THE 90'S
WHICH WORK FINE ON MY PHILIPPS CD-R, BUT THE NEWER AUDIO CD-R BLANKS (FROM YRS 2000? TO THE
PRESENT) CAN'T BE RECOGNIZED BY THE PHILIPPS CDR 765. OUTDATED LASERS IS THE PROBLEM. BETTER TO BUY ANOTHER ONE. AS MANY AGREE WITH ME, WE ARE OWED SOME COMPENSATION FROM PHILIPPS. I PAID
AROUND $450 FOR MINE WHEN IT FIRST CAME OUT ON THE MARKET.
Posted on Feb 18, 2008
I have this exact same problem. I let the unit sit for a year until I could get back to it and guess what, both drives worked for a few minutes. Then, the non-recording side died again, "No Disk" messages then the recording side died. I started looking at the power supply since both sides would have this in common. During this process of debugging I damaged the power supply. I bought a new one (faster then fixing it, it needed the PWM chip and the FET). I still get the same problem on the non-recording side, the recoring side seems to still be working however? Note, the supply got damaged because the big capacitor which filters the High Voltage DC before it is switched down to the lower voltages, stays charged after power down, for a long time. I actually had the board removed and on the bench when two leads of the FET were shorted by a tool on my bench which destroyed the FET and the PWM chip. I opted to replace the whole thing thinking this was the issue anyways, wrong again. One side does work now. I am still working on this so look for more information soon.
Posted on Mar 29, 2007
Hi, I have a Philips CDR 765 CD Recorder Player. I have been using special disks RAA 80M-51036 80DA and am running out. Where do I get new disks? Peter P. Fuchs
Yours is the only context Google can find for that disk type. What's so special about them?
The recorder will work with any disc on which "the text 'DIGITAL AUDIO' is present!"
http://www.retrevo.com/support/Philips-CDR765BK-CD-Players-manual/id/364dj382/t/2/
Look on eBay. That's where I get mine in bulk. Stick with brand names.
Jul 25, 2011 | Philips CDR765 2-Disc CD Recorder
NECESITO EL PLANO O DIAGRAMA ELECTRONICO DE EL EQUIPO -PHILIPS AUDIO COMPACT DISC RECORDER CDR 765. DESDE YA, LES AGRADEZCO SU ATENCION CARLOS CISNEROS
la solucion a el manual de esta grabadora esta en retrevo.com/manuals.. ellos tienen infinidad de manuales para toda clase de aparatos electronicos incluyendo grabadoras de cdr..espero tengas suerte en encontrar el manual..suerte
Jun 17, 2011 | Philips CDR765 2-Disc CD Recorder
I have a CDR 765 Philips recorder. It doesn't work on recording. The error message is "NO OPC". Thank you
hola
la cdr765 de philips es una grabadora de pc 3610 de philips o hp7200, el opc error es la lente esta mal, compra ina grabadora y cambia los 2 circuitos de la mecanica original de la cdr765 y desmonta la 3640/7200 y ponle los circuitos montas y a disfrutar.
Feb 27, 2011 | Philips CDR765 2-Disc CD Recorder
Can i connect my mixer to the input of the cdr 765 then connect the amp to the outputs. Will this work and record?
If you just treat the CDR as a tape deck, I'm pretty sure your mixer has accomodations for that. Then you won't have to connect the amp to the CDR and anything you want to mix/monitor will be available to the amp.
Jan 11, 2011 | Philips CDR765 2-Disc CD Recorder
CDR 765. Recording side will not recognize disc.
Try to clean laser with cleaning disc.I had the same problem and cleaning disc resolved the problem
Mar 09, 2017 | Philips CDR765 2-Disc CD Recorder
CDR is not working
have a look on ebay for a cheap working donor recorder as spares are very expensive and very hard to get hold of.
i'm guessing your recorder either doesn't read discs, or it won't eject? which is very common and means either the servo board is faulty or the laser.
The following recorders i know off hand for a donor mechanism are:
MARANTZ DR-6050
PHILIPS CDR-775
PHILIPS CDR-770
if it proves to be just a faulty laser, all 3 of the above have the same laser unit.
if it proves to be a faulty servo board, all 3 have the same servo boards except if you fit one out of a philips model it will show 'PHILIPS CD RECORDER' on the display at power up but will still work nontheless.
obviously if a marantz is found it will show 'MARANTZ CD RECORDER' as normal.
hope this helps.
Aug 27, 2008 | Marantz CDR500 2-Disc CD Recorder
Philips CDR765 2-Disc CD Recorder Logo
1,275 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
