Question about Microsoft Windows Vista Ultimate Edition
Com surrogate and run ddl 32 problem
Whenever i am opening a video file this display is coming com surrogate and rundll32 stopped working i want a solution
  • bobby22 Jan 19, 2009
    when i open a file containing a viedo or audio file the com surrogate error occurs
  • Anonymous Mar 09, 2009
    same problem
    Genius:
  • Microsoft Master
  • 1,250 Answers
Download codec pack and install it, ex - k-lite codec pack its free on net
Posted on Nov 11, 2008
If I diable com surrogate will it harm my computer
Com surrogate is a service that allows switching on the com ports. Without it, communication to your devices will stop. If you're encountering this error there is a driver problem with your com port controller and you need to install the correct drivers.
Sep 01, 2014 | Microsoft Windows Vista Home Premium...
Rundll32 stopped working
Make sure that your all your drivers are up-to-date, and then follow the below procedure:
  • Right click on Computer > Properties
  • Click on Advanced System Settings
  • Performance tab > Settings
  • Execution Prevention tab data
  • Check the second proposal
  • Click on Add
  • Select: C: Windows/System32/run32dll.exe
For those who have the "COM Surrogate" problem add the dllhost.exe file that is also located in the System32 folder.
Jan 09, 2014 | Acer Aspire Computers & Internet
In windows vista ultimate 64 bit. most of the items in my control panel will not open up. I get this message. c:\windowssystem32 undll32.exe file name or extension is to long. can you please help me. jim
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte_2/misspell.gif) repeat-x scroll center bottom; } hi
The rundll32.exe process is responsible for running DLLs and placing its libraries in the memory. The rundll32.exe process is known as a command line utility program, and it performs its embedded functions along with the rundll.exe file. Rundll32.exe works by invoking a function that is exported from a specific 16-bit or 32-bit DLL module. However the only DLLs that you can call with the rundll.exe and rundll32.exe files are the ones that are only specified to be accessed by these processes.
The rundll32.exe file operates by parsing the command line. The specified DLL is then loaded through the function LoadLibrary(). Afterwards, from the function , it gets the addresses through GetProcAddress(). The command line tail is passed when the is called. Next, the DLL is unloaded upon the return of . Finally, the rundll32.exe file exits.We strongly recommend that you run a FREE registry scan to identify rundll32.exe related errors.
if you have any question or any futher assistance you can get back to me on fixya for same
thanks
techbuddies
Oct 25, 2009 | Microsoft Windows Vista Ultimate Edition
Com surrogate has stopped working.
find the link for the software u need on this website http://vistatipsforall.blogspot.com/2007/05/com-surrogate-has-stopped-working-error.html
May 31, 2009 | HP Computers & Internet
Com surrogate
These should help:
http://www.howtogeek.com/howto/windows-vista/fix-for-com-surrogate-has-stopped-working-error-in-vista/
http://www.superbdevelopment.com/forums/general-tech-talk/3600-windows-vista-com-surrogate-has-stopped-working-fix-solution.html
http://www.mydigitallife.info/2008/06/13/how-to-fix-com-surrogate-problem-when-opening-video-format-files/comment-page-1/
Error message: "COM Surrogate has stopped working."
COM objects are often defined in Dynamic Link Libraries (DLL files). The Program file for COM Surrogate is actually dllhost.exe that can load a DLL and make its objects available to other programs.
The COM Surrogate error message is often related to codecs and other COM objects that aren't fully compatible with Vista. These are installed by other programs. The most common culprits are DivX and Nero. The first thing you should do is upgrade to the latest versions of these to see if that fixes the problem. Another possible fix is to disable thumbnail previews in Explorer. To do that:
In Windows Explorer, click Organize, then select Folder and Search Options
Click the View tab
Check the box that says "Always show icons, never thumbnails"
Click OK
To help troubleshoot which codec(s) might be causing the problem, you can use a free tool called InstalledCodec. You can use it to disable individual codecs one at a time.
You can download it at http://www.nirsoft.net/utils/installed_codec.html
Hope that helps
Mike
May 13, 2009 | Dell Inspiron 1521 Laptop
Com surrogate
First check if you have nero or Divx installed. Then uninstall it.
Right click on Computer, and choose Properties
clip_image0021.jpg Click on Advanced System Settings, and then under Advanced, click Settings
clip_image00211.jpg Select the "Data Execution Protection" tab, and then click “Turn on DEP for all programs and services except those I select�
clip_image00221.jpg Click on the Add button, and then browse to C:\Windows\System32\dllhost.exe as shown
clip_image00231.jpg Click Open, and then OK.
Here's what you should see…
clip_image00241.jpg Now you can browse video folders without problems!
Feb 02, 2009 | HP Compaq Presario F750US
http://fileforum.betanews.com/detail/Vista-Codec-Package/1159994557/1
Just download this small program and everything should be just fine . I was having the same problem , ive been told that its because of nero or divx codecs , didnt unistalled anything just installed this program and my problem was solve !
Nov 28, 2008 | HP Thin Client - AMD Geode NX 1GHz - 256MB...
Windows Explorer sends continuously error messages
Turning off thumbnails will probably stop you getting that error
DO:
Open Control Panel > Folder Options > Always show Icons, Never Thumbnails
However, this isn't actually fixing the problem.
Do you have Nero installed by any chance?
If so try:
Open Computer > System Drive > Program files > Common Files > Ahead > DSfilter.
Rename "NeroVideoProc.ax" to "1NeroVideoProc.ax"
Also rename "NeVideo.ax" to "1NeVideo.ax"
And then reboot.
Nov 11, 2008 | Computers & Internet
Software problem
Hey there
You get an error message that COM Surrogate has stopped working whenever you browse folders containing video or media files, This problem is caused because of codecs and other COM components installed by various softwares that aren't fully Vista-compatible, like some versions of DivX or Nero.
There are a number of possible solutions to this problem, and the right solution depends greatly on what software is actually causing the problem.
If you are using DivX, you should be upgraded to the very latest version (6.5+)
If you are using Nero, you can try upgrading to the latest version (7.7.5.1+)
If you’ve upgraded Nero and Divx and still have the problem, you can try renaming the file C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax to NeVideo.ax.bak. You may also need to rename NeVideoHD.ax to NeVideoHD.bak
Essentially, turning off Data Execution Prevention on dllhost (the COM surrogate) can fix this problem . This solution is detailed below.
Select the "Data Execution Protection" tab, and then click “Turn on DEP for all programs and services except those I select”
Gimme your Acknowledge by rating me
thanx
Romy
Jul 31, 2008 | Microsoft Windows Vista Ultimate Edition
Rundll32 Error
copy rundll32 from someother vista laptop and replace yours.
May 24, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
291 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
