Home | Toshiba | Satellite A135-S2386 15.4" Notebook PC (In... | Toshiba Satell T2080 Web...
Toshiba Satellite A135-S2386 15.4" Notebook PC (Intel Pentium D Processor T2080, 512 MB RAM, 80 GB H... PC Notebook
Problem for Toshiba Satellite A135-S2386 15.4" Notebook PC (Intel...
Toshiba Satell T2080 Webcam(''Chicony USB 2.0 camera'')not working
By gor.mack67 on Nov 11, 2008
The webcam on my laptop works about 1% - 2% of the time. 98% of the time it does not work. The laptop is brand new...less than a year old. I ran Driver Detective on the laptop and it tells me the driver for the camera is working and up to date. I have had this problem since day 1.
When I try to start the webcam it tells me any of the following messages: "the webcam is not connected, sorry, no webcam was found on your system" or that it is "blocked by another application."
I contacted Toshiba a couple of months after purchasing the laptop and told a lady about the problem. (I am no genius on computers, so I hope you keep this in mind when you correspond with me...layman's terms only please.) The woman had me go to different places on my laptop...looking back I have no idea where...she told me to check certain boxes or uncheck certain boxes which I did. She told me the webcam is used by several programs on the computer and in the end she had me blocking certain startup programs. In the bottom right of my monitor their is an icon for "Blocked startup programs." When she had gotten to the end of guiding me here and there, checking or unchecking boxes...the webcam had started working. It is important to mention though, it had worked sporadically since I bought the laptop. So, was this just a coincidence? The next time I went to use the webcam, I was right back at square one. The webcam was not working again and giving me the same old messages.I was really ********** because I had done everything she had told me, and in addition, I now had blocked startup programs and still had the same problem with the webcam that I had from the very beginning. Also, it seems kind of ridiculous to me that I had to block certain startup programs to begin with. A new computer and you have to block certatin programs to use the webcam. (Just also remembered, I have a burner on this laptop and when I have tried to burn downloaded songs to disc, it shows that songs are being burned, but upon playback the disc has nothing on it. My sister tried using the disc after to burn music...thinking maybe the burner had not done anything to the disc... and the disc would not record a thing. :-( It just became a piece of garbage. I did this with three discs. She took two of my remaining discs and burned downloaded music and did playback on her own pc with no problem whatsoever. So, based on this, the discs were not the problem.)
Back to the webcam problem: For your information, I have closed yahoo messenger and windows live messenger to see if that makes any difference. The webcam still does not work. Now and then...by no means always...I shut down the computer and sometimes...not very often, however, when I try to start the webcam the stupid thing works. Right now, it is not working again and I am at a total loss for answers and extremely frustrated. My gf is a nurse stationed in Afghanistan. I am able to see her camera, but she is unable to see me. When I try starting my webcam she just sees the same words that I see... that I
have cancelled my invitation to view webcam. It is very upsetting to her that I haven't been able to get this problem fixed. Could you please contact me at your first opportune moment and if at all possible help me to fix this problem once and for all. I would be deeply appreciative and I assure you she will be also.
I am running Windows Vista Home Premium. The laptop is a Toshiba Satellite T2080. When I scanned the laptop with Driver Detective...I think that is the name of the program...it said the laptop is A200. I don't know if that helps you or not. In any event, whatever information you may need that I have not provided... in your correspondence simply direct me to look for... or do whatever is necessary to help you resolve the problem(s). In the meantime, I hope I have not confused you with my explanation of the problems by being so long winded. I am more than a little anxious to hear from you very soon! Thank you.
Sincerely,
Gordon Mackey
Same Problem
Dec 06, 2008
-   same as above -   nchovatiya
Solution #1
posted on Dec 09, 2008
Not Rated)
Rock1061
Rank: Apprentice
Rating: 0%, 0 votes
Well it's not a complete solution but this does work. It's just a bit of a pain. Go to Control Panel > Device Manager. Now you have one of two options either update the software this works from time to time. Alternatively, disable the camera. Restart and enable it again and it should work.
Hope it helps,
Phoenix
Comments:
Dec 11, 2008
- Just figured out you don't even need to restart just disable it and enable it again. Then open it in the program you want. It usually works.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite A135-S2386
Questions and Unsolved Problems for Toshiba Satellite A135-S2386
Do you recommend Toshiba Satellite A135-S2386 15.4" Notebook PC (Intel Pentium D Processor T2080, 512 MB RAM, 80 GB H... PC Notebook?
Answer
Answer
i can not log to my account on my laptop and login passward is also correct but it shows only... (More)
Answer
i accidently uninstalled my camera assistant software for toshiba off my laptop can you help me
Answer
toshiba a305-s6898 computer starts up and goes to black screen what can fix this
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba Satellite A135-S2386...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
