Question about Nokia N73 Cellular Phone
N73 can't charge battary and overheats
I can't recharge my battary and the phone heats up when connected to the charger.
as a result my memory card doesn't work.
is it a battary problem or somthig i can fix with software?
REFORMAT YOUR CP
Posted on Nov 13, 2008
I have gfive mobile but when i plug the charger then showing bad contact charge,plz help me,i changed charging jeck,battary and charger but same result
If your old phone has the photos stored on a mini SD memory card, then remove the memory card and insert it into an USB card reader then connect it to the computer's USB port. The computer will see this as an external storage device, you can then open the folders and photos on this mini SD memory card and copy the photos into your computer.
Sep 04, 2011 | Computers & Internet
How to remove memory card my n73
The memory card slot for Nokia N73 is located at the bottom of the keypad just above the charger connector.
  1. Before you eject the card, press the power key, and select Remove mem. card. All applications are closed.
  2. When Remove memory card and press 'OK' is displayed, open the door of the memory card slot.
  3. Press the memory card to release it from the slot.
Do not remove the memory card in the middle of an operation when the card is being accessed. Removing the card in the middle of an operation may damage the memory card as well as the device, and data stored on the card may be corrupted.
Jun 29, 2011 | Nokia N73 Cellular Phone
Hi i have a 2gb micro sd card for my nokia i got it with my phone last month, i was working in it up till now, my phones battary died so i recharged it so that i can put music on it and now it wont read...
Try to take the card out, switch the phone off , then on, then put the card back in.
then try switch off the phone, take card out, switch on, put card back in.
Dec 20, 2010 | SanDisk 2GB microSD Memory Card
Hello i replace my small ups 650VA battary with a car battary,when i charge the car battary with an external charger does this affect my ups if it remain connected with the battary
Should not be a problem - just make sure the charger is a good one, and avoid over-charging. Once the battery is fully charged, the UPS should maintain it properly. Also, check the water level once a month - dry cells will kill the battery.
May 04, 2010 | PC Chips M871G Motherboard
Phone was working fine then battery went out of charge,when I got home I PLUGED IN MY CHARGER AS NORMAL BUT NOTHING I HAVE TRIED SEVERAL TIMES TO GET TO GHARGE BUT NOTHING.
Try these and tell me the result.
1. Try to charge from a different charger.
2. Use another battery and try to on the phone.
3. After plug on the charger press power on/off button for a while. If nothing happened on your mobile after use these 3 tips then visit Nokia service center for installing the operating system on your phone. If the OS is corrupt then the mobile going under dark. No movement, no signaling of charging nothing. Even you can't update it from internet right now. Because the phone memory is fully dead. Its happened with all mobiles if the OS corrupt. Its was happened also in my Nokia N73.
Thanks &waiting for your reply.
Feb 04, 2010 | Nokia N95 Cellular Phone
PC SUITE via DATA CABLE, my n73 shut off
First remove any memory card inserted then try to power ON with charger connected ..
Aug 11, 2009 | Nokia N73 Cellular Phone
NOKIA N73 PROBLEMS
my n73 hand set problem is if i connect the charger on the screen displayed not charging, and i use to charge the battery charger to store power in battery. charger is working fine but hand set troubled me and the other problem is if i listen the music files after 2 minutes phone is off, in a day its happening lot of times give a complete repairing solutions.
Jul 16, 2008 | Nokia N73 Cellular Phone
Unlock memory card
You can't do it with your phone. You need extra hardware and soft for unlocking mmc.
May 19, 2008 | Nokia N73 Cellular Phone
N 95 memory card locked
there is a small handel on the side of it move it to unlock the card.
Mar 31, 2008 | Nokia N95 Cellular Phone
My N73 is not charging
try to replace ur charger, coz charger not compatible to your phone.
Feb 07, 2008 | Nokia N70 Cellular Phone
Nokia N73 Cellular Phone Logo
146 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
