Question about GE JVM1440 Microwave Oven
Unit shuts off (JVM1340WW002) and blows fuses
The power on my microwave JVM1340WW002 started to go down after few seconds into operation (~5 sec not right away) and then shut down completely. Found that fuse was blown. After replacing the fuse it would shut down as soon as it would start, blowing the fuse again. The High power Capacitor and rectifier show no visible sign of damage. Checked door switch and thermal sensors (two of them - both fine: one is normally open). It leaves either HV Capacitor/Diode, Transformer or Magnetron (still under warranty). I would be inclined to suspect the Capacitor, but the fact that microwave was able to start and died down in few seconds raises doubts. My understanding is that HV cap is there to provide the boost on start up only. Please help.
  • 1 more comment
  • Ryan Narod
    Ryan Narod Nov 07, 2006
    I appreciate the initial respons on below problem description, but need further clarification. Though the fuse does blow as soon as I hit the "Start" keypad, pointing to faulty HV Cap, the way the microwave died is a suspect. As I described, it started fine and died down after few seconds - you could hear as the power just start going down. Can HV capacitor die in such a way?
  • Ryan Narod
    Ryan Narod Nov 12, 2006
    Your answer provided high level of experise and I was ready to buy the HV Capacitor, when the Repairclinic.com answer came in and it is as follows (see my comments back to them when they first pointed to a door switch):
    Repairclinic.com (they first blaimed the door switch):
    This microwave has 3 door switches, 2 secondary and 1 monitor. From that description it sounds like a bad high voltage component like the magnetron or transformer.
    Hate to be a pest, but could the the magnetron or transformer be faulty? Or these guys at Repairclinic.com just paying me a lip service - just like the first time when they said its a door switch? Here is what I wrote to them before they came back with "magnetron or transformer" explanation:
    My foolowup with Repairclinic.com: I appreciate the initial response on below problem description, but need further clarification. As I decribed, I checked the door switches - all fine. I was hoping for more meaningfull answer. Though I suspect the HV Cap, the manner in which the micrawave died may or may not be consistant with Ccap failure. The microwave initially started fine but started to die after few seconds (3-5 sec)- you could hear as the power just start go down. After the fuse replacement it would blow it as soon as I hit the "Start" keypad. My question: Can the initial non-instanteneous failure be attributed to HV capacitor problem or is it something else (transformer or magnetron or triac)?
  • jkromo Mar 21, 2008
    My GE JVM1650 will run for a few seconds and then shut off. After resetting the clock and date, sometimes it works fine and sometimes it will shut own again. I have unplugged the microwave and plugged back in a few minutes later. Sometimes the microwave will run properly and sometimes it shutts down after a few seconds.
  • GE Master
  • 9,156 Answers
Generally speaking, if the high voltage capacitor is shorted, the fuse will blow as soon as you hit the START pad. When the HV cap fails, I've never seen one do anything but short. If it's a few seconds or so into cooking, it's usually the high-voltage transformer. There may or may not be a burning smell. The cooling fan often will dissipate the smell. What can happen to the transformer is an expansion of the windings to the point where a couple of hot spots eventually make bare spots which touch, then the short causes the fuse to blow. When it cools, they aren't shorting anymore. It's possible it's the mag or something else, but not too likely. You can (carefully!) disconnect the primary leads from the HV transformer then run the oven, making sure the wires are free and clear. If the fuse blows, the problem is in the low-voltage side. If it doesn't the trouble is in the HV side. If you broke a seal (tamper tag) or left any other evidence that you were inside the microwave, your warranty will be voided. Some parts may be covered, but the labor warranty usually expires sooner. Be careful.
Posted on Nov 07, 2006
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ran on power for 10 minutes, thought it was on timer.
First, check the fuse usually located above the display, inside the top lid.  You can't see if it's blown, so you must test it for continuity with a meter or self powered test light.  Usually fifteen amp, and of the ceramic variety.  (available at radio shack type places) If the new one blows instantly, it's likely a door switch shorted out.  If it blows after a few seconds, it could be the magnetron gone bad, or internal arcing.  The main transformer will sometimes short out, but that's rare.   Be absolutely careful, should your fingers venture around the magnatron connections down below, as there is high voltage and current that can kill you.  This warning applies even when it's unplugged!
The door switches operate together, so if one slams the door shut it will often blow the fuse with no other damage.  Sometimes the crow-bar switch will sustain damage in the process.  Usually, if the switches click individually, they're good.  If one doesn't click, it'll almost always be shorted.  They're located behind the door catch, inside the unit beside the display board, and a bit hard to access.  You will need to reach past the magnatron for this, so be careful.
Jul 15, 2009 | Whirlpool GH6177XP Microwave Oven
Microwave turns itself off after a couple of seconds
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No power to GE Spacemaker Microwave
I have model GE Microwave serial # JVM2070SK02. I start to cook something and it shuts off 5~10 seconds. Keyboard is still lit up, but no clock, fan, light and you cannot operate anything on the key pad. Unplug the unit and it resets. Sometimes it cooks, sometimes it doesn't? It is getting more frequent with the shutting down problem?
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave emerson not turning ON
That makes it sound like a bad high voltage transformer.
Do you detect any burning smell?
Do the windings of the high voltage transformer seem blued or blackened?
They should be copper colored or maybe a little darker due to the varnish.
Apr 01, 2008 | Emerson MW8775W Microwave Oven
Unit Electrical Problem
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
Microwave can be very dangerous so it is best to have it looked by a professional
Would appreciate a solved rating for expert advise.
Oct 16, 2007 | GE JE1590 Convection / Microwave Oven
Final follow up to: Unit shuts off (JVM1340WW002) and blows fuses
> My question: Could they be right about the transformer and magnetron? It certainly could be the transformer or the magnetron, but I really don't think so. Not that I'm recommending that an inexperienced or unqualified person should do this - and bearing in mind that any person who would do so must assume ALL liability for injury or damage - here's how I (on a VERY careful day *grin*) would find out: - I would disconnect the oven's power cord from the wall - I would remove the outer cover - I would discharge the high voltage capacitor - I would look again to be sure the plug is out of the wall - I would make a careful note of and/or mark the exact connections of the wires going to the HV capacitor - I would be very careful in case the connectors have positive locks and not yank on them before I push in the locks - I would disconnect the wires from HV capacitor - I would set my meter to a medium or high resistance scale and touch one probe to each capacitor terminal and from each terminal to the case of the capacitor - If either reading held steady at less than infinity I would replace the capacitor, reconnect the wires, reassemble and test - If neither reading held steady at less than infinity I would reconnect the wires - I would then make a careful note and/or mark the exact locations of the wires attached to the transformer - I would then disconnect just the lead which goes from the secondary of the transformer to the capacitor - I would then remove the other end of that lead wire - I would then insert a new fuse then plug the microwave into the wall and test it - If the fuse blew, I would know it's not the capacitor or the magnetron and I would troubleshoot further - If the fuse did not blow, I would know it's the magnetron or the capacitor (but I just measured the capacitor and it's not shorted!! *grin*) - I would unplug it again from the wall - I would install a new capacitor, hook it all back up, install a new fuse, reconnect the wires, and test it again Sorry to be so stiff about my reply, but I do not want to advise or suggest that an untrained or inexperienced should troubleshoot or work on a microwave oven. The voltages can be instantly lethal. Good luck and be safe!!!
Nov 12, 2006 | GE JVM1440 Microwave Oven
Follow up to: Unit shuts off (JVM1340WW002) and blows fuses
In my 20 years of working on microwaves, I have never seen a capacitor fail in any way but a dead short, but it's possible that it's failure may occur in a less abrupt manner. The internal structure of a capacitor is essentially a rolled up sandwich consisting of two thin layers of foil separated by a very thin insulator. While a "perfect" capacitor consumes no power, in the real world, things can happen to change that. A defect could increase the capacitve reactance or other internal resistance and allow internal heat buildup or expansion, which could lead to an intermittent short when it's warmed up a bit. After a while, the short could become permanent - sort of like arc welding, if you're familiar with that. So, while it's quite possible that this is the pathology that lead to a fully shorted capacitor, I think that's what you have, no matter how it happened.
Nov 07, 2006 | GE JVM1440 Microwave Oven
Microwave not works
WARNING: Microwave ovens are the most dangerous consumer appliance to service due to up to 5,000 V at high current inside. Even with the power off, there is a HV capacitor that can produce a lethal kick. This capacitor must be discharged before touching anything in the microwave generator circuitry. DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. About the only "easy" fix would be a blown fuse, if it keeps blowing, don't go any further unless you know what you are doing. Your likely options are a blown high voltage cap, diode, or the magnetron. Good luck(but luck has nothing to do with it ;] )
Apr 01, 2006 | Sharp R-320H Microwave Oven
GE JVM1440 Microwave Oven Logo
976 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
