Question about Belling Refrigerators
No temperature going into the fridge. The light is still on and the freezer works but the fridge is just not cold
  • randumpunter Nov 11, 2008
    No there isnt. The freezer isnt frozen, theres no build up of ice at all.
    Strange - the light still comes on in the fridge, freezer works, but no cold going into the fridge part.
    Genius:
  • 1,122 Answers
Is there frost in the freezer?-mike
Posted on Nov 11, 2008
  • MIKE major Nov 11, 2008
    i would think the frig.port from the freezer is block with something not letting cold air from the freezer get to the frig. have you checked to see if that is frozen over?mike
Fridge temperature has stopped working but freezer is still workijg but fridge light still on..help asap!!!
OK! The light on the fridge is activated by a switch on mounted somewhere the door hits to turn it off when the door is closed. How do you know the light is on if the door is closed. Check the switch and manually press it in. If the light doesn't go out the switch is bad and will have to be replaced.
The second issue of the Freezer working but the fridge part not working. The cooling coils are located behind the rear panel of the freezer. If the blower is blowing, you may have a chronic ice build up on the coils which limits air flow. The fridge is supplied its cold are through the vents at the back of the freezer along the bottom and cold air is blown into the fridge through these "Vents". Make sure nothing is obstructing them. Hope this helps.
Bill
Sep 27, 2016 | Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
THE MAIN FRIDGE IS NOT WORKING, THE TEMPERATURE SEEMS TO BE VERY WARM. THE LIGHT INSIDE THE FRIDGE IS WORKING OK AND SO IS THE SOUNDER WHEN THE DOOR IS LEFT OPEN.
Listen for the fan that is in the freezer section. The fridge part relies on the freezer fan to get it's cold air. Only the freezer section gets cold...the fan in the freezer blows cold air through ducting to the fridge to get it cool. Either the fan is bad or the air ducting to the fridge is restricted by ice. If the airway is restricted by ice then your defrost timer is bad. Good luck.
barneyluc
Oct 10, 2008 | Refrigerators
MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Oct 08, 2008 | Whirlpool Refrigerators
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Our beko frost free fridge freezer has stopped freezing. The fan is working and the freezer section cold but not cold enough. Thermostat is in the fridge - the fridge is icing up.
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Aug 12, 2008 | Refrigerators
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Refrigerators Logo
207 people viewed this question
Top Belling Refrigerators Experts
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
Nater13
Are you a Belling Refrigerator Expert? Answer questions, earn points and help others
