Question about Brother Office Equipment & Supplies
Brother hl 2040 laser printer all the lights are flashing after changing toner cannot get it to reset
  • jfisher38 Dec 24, 2008
    Without changing toner - in normal use - all LED lights are on. Turning machine off and on, then all lights flash. How to reset this??
  • Anonymous Feb 14, 2009
    Toner light keep on even thugh a refill the toner. In there an reset switch tp turn it off
  • 4 Answers
On the brother printers, the fuser is often attached to the toner (they come out as one piece). If you look at the old toner, you will probably notice that it is longer than the new one. The extra piece that makes is longer needs to be taken off of the old toner and attached to the new one.
Posted on Nov 12, 2008
All the light flashing
Try this procedure as mentioned.if any mistake in trying the procedure then retry from first step again.so read it carefully and try it. Brother ML-2040 Toner Light Reset
When replacing the toner cartridge in the Brother HL-2040 with a new cartridge (compatible or remanufactured) the user may experience a problem with the toner light staying on, even with the new toner installed. The procedure below has worked for many folks, so give it a shot.
Open the front cover of the Brother HL-2040 and leave open while completing the following steps:
1.) Turn the printer off.
2.) Hold the ‘go’ button while turning the printer on. All panel lights should be on.
3.) Release the ‘go’ button once all lights are off.
4. )Press the ‘go’ button 2 times.
5.) Pause.
6.) Press the ‘go’ button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your “low toner” light should be fixed.
------------- From Brother Service Bulletin
1. Open the Front cover
2. Press and hold the GO button
3. Power ON the printer while continuing to hold the GO button
4. Once the 3 LED’s are lit, release the GO button
5. Press the GO button 2 times. This will cause the LED’s to light solid
6. With the LED’s lit solid, press the GO button 5 times
7. Toner Life End will then reset
8. Close the front cover.
----------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 02, 2010 | Brother HL-2040 Laser Printer
Toner light is flashing and printing has stopped
Hello ,
This problem is a common issue and easily fixed.
When putting in a new toner cartridge, the printer usually automatically resets the toner count.
In a situation like this, the printer did not automatically do the reset and so we must manually reset the printer.
To manually reset the printer, first, remove the toner from the printer and separate it from the drum unit.
With the toner cartridge in hand and the brother writing facing you, look to the left side of the cartridge. You should see an arc shaped opening with a white tab in it.
The tab is set at the right position and must be pushed back to the left side of the opening.
To push the tab back, you must turn the grey gear attached to the front roller upwards as you push the tab.
Once the tab has been placed to the left position, the printer will accept it as a new toner cartridge.
Thanks,
Pat
Apr 01, 2010 | Brother HL-2040 Laser Printer
Resetting toner cartridge on brother hl 2040 printer
Just push down the blue buttom for 1 min.
after you see 4 lights then it's okie now.
Sep 11, 2009 | Brother HL-2040 Laser Printer
Please describe your Brother HL-2040 Laser Printer problem
Yep this will always happen if your just using a replacement toner. They will be depleted faster compared to the original Brother toner.
Make sure you replace your toner with the original Brother toner.
Aug 24, 2009 | Brother HL-2040 Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
TONER LIGHT FLASHING, CANNOT GET IT TO STOP
No you can't, until you replace it....toner cartridges are on an electronic counter that is only reset when a new cartridge is installed......don't you love "brother"?
Mar 10, 2009 | Brother HL-2040 Laser Printer
Won't feed paper
It has toner? if not replace new one. If it has toner then try to remove the catridge and place it again. This might help you.
Mar 02, 2009 | Brother HL-2040 Laser Printer
Hl 2040 laser printer
Check for a piece of paper caught in the fuser section. Sometimes a small piece will wedge itself in. Vacuum out any residual toner that may be in the paper path.
Dec 01, 2008 | Brother HL-2040 Laser Printer
Brother HL 2040 toner light flashing
Push the start buttom and hold for 30 sec.
Nov 26, 2008 | Brother HL-2040 Laser Printer
HL-2040 CHANGE TONER
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
Dec 22, 2007 | Brother HL-2040 Laser Printer
632 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
