Question about Kenmore 55692 / 55694 Side by Side Refrigerator
Always crushes ice
The Ice make shows cubed ice on front but you always get crushed Ice. The lite changes when pressing buttons but we no longer get cubed ice. Did something get out of sync?
  • Anonymous Feb 14, 2008
    always crushes ice will not cube
This was easy to solve after reading some posts which mention "a plastic flap" which is opened or partially closed by the metal rod running under the ice cube tray.
There is indeed a flap which is inside the front of the removable ice holder/dispenser. The flap should be able to open fully so ice can fall out. In mine it could only move 1/2 inch because the flap was laying on the wrong side of a small peg which guides it.
I was unable to free the flap to open completely by pressing on it, so I had to unscrewed six screws to take off the front plastic facing and the on the front plastic housing. Pushing on the metal rod immediately put the flap back into it's correct position. I then replaced the plastic front.
I can now have either whole cubes or crushed. Boy was that easy to fix!
A repairman recommended replacing the electronics ! !
I assume this misalignment might be caused by too much pressure when the ice cubes freeze solid or something? If it happens again, I know it's easy to fix.
Posted on Aug 18, 2009
I've had the same problem for a year now, the problem with mine is that the freezer is getting to cold and busting the cubes. replaced circuit and temp switchs twice. still the same problem, now im calling Samsung.
Posted on Feb 06, 2007
I had this same problem and all I did was empty all the ice out and cleaned the forks that turn. I did notice that there were some cubes stuck under the long rod that turns to dispense the ice. When I put the ice back in, it was working fine. I have not tried crushed ice again though.
Posted on Jan 06, 2007
I was only getting crushed ice and I emptied out the ice holder and cleaned the fork that turns and when I put the ice back in, it started dispensing whole ice like it was supposed to. I had noticed that there was some ice stuck under the turning device in the bottom of the ice holder, so I figured it must have kept it from turning properly.
Posted on Jan 05, 2007
  • 237 Answers
Sounds basically like the selector switch is broken (stuck in crushed mode). These are usually controlled by circuit boards (about $40 bucks). Pretty easy to change out but first check that the plugs are not loose on the circuit board.
Posted on Nov 10, 2006
  • Marc Wilson
    Marc Wilson Dec 04, 2006
    Not sure if you had any more time to review posts. If the selector isn't stuck check the solenoid in the rear that lifts the lever rod on the side, it could be stuck in the up position (frozen) or the power to the solenoid is missing and won't operate the lever.
Why am I getting crushed ice when I have it on cube ice
there's a shifter rod that runs along the side of most ice containers that ships it from crushed to cubes try to manually move that rod if it does not move then check for the rod being frozen somewhere. when you press crushed there's a solenoid valve that is supposed to move and actuate that rod. you will have to press the light switch to the off position while someone presses the crushed ice and cute as buttons to cs that solenoid moves the ice maker and that solenoid will not do anything with the light on. the light on indicates the door is open and it's in the interlock. I'm here to help you if you will answer this post I can't help you if you don't answer.
Appliance 911 Sea Breeze
Dec 02, 2015 | Samsung 28 Cu Ft Stainless Steel French...
Why would crushed ice come out when cubed ice is selected?
There is another set of blades that pull in to crush the ice... they are stuck in the crushed position causing you to get crushed ice always...
See if the solenoid is stuck or bad that moves the crushed ice blades...
heatman101
Aug 22, 2011 | Maytag Refrigerators
I took out the ice tray and it looks like the drive mechanism inside the frig that interlocks with the tray needs to spin counter clockwise to release cubes and clockwise to chop the ice. No matter which...
The first place I would check is the solenoid listed as position 33 here=> MSD2756GEW Ice Bin and Components When switched to crushed to not crushed that activates the shifting lever to create crushed. First unplug refrigerator and then unplug the coil and check resistance with an OHM meter. When energized with 120 VAC the coil should pull a strong magnetic field through the center. Give that a try first. Part is=> 61005253 SOLENOID
sea_breeze_136.jpgCrushed-Cubed Ice Solenoid
Let me know what you find, Thanks, Sea Breeze
Apr 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
My samsung rfg297aa dispenses crushed ice whether its set on crushed or cubed. why will it no longer dispense cubes?
This answer probably comes too late for you (you posted the question 9 months ago), but I want to record it here for posterity, since I had the same problem, and searching on Google for it brought up your question.
Anyway, I managed to fix this very problem by removing an ice cube that was wedged in the ice dispensing mechanism. The way this unit works is that it pushes the ice cubes through the mechanism, which always rotates the "crushing blades". When you select "cubed" ice, a lever opens up the exit chute wider, which causes the blades to simply push out the ice cubes as they pass through. When you select "crushed" ice, the lever closes the "exit" for the ice cubes to be narrower, so that the ice cubes can't be pushed through by the blades, and instead get crushed by them. I had an ice cube wedged in there that had the same effect of closing the exit to be narrower. Removing it fixed the problem.
You might want to collect all the ice cubes that have accumulated in the ice bucket in a container, empty the ice bucket, clean out the mechanism from any obstructions, and then put the ice cubes back into the ice bucket.
Feb 16, 2011 | Samsung RFG297AA (285 cu ft) Bottom...
Ice that comes from the door is always crushed
empty out all of your ice than wait for it to fill up a new tray and than it should be cubed if it doesnt change you might end up sticking with it because you will need to change the control panel behind the buttons your pressing
Jun 08, 2009 | GE Refrigerators
Ice dispensor only dispensing crushed ice - not cubed
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
Dec 02, 2008 | GE GSH22JFT Side by Side Refrigerator
Admiral Fridge Freezer
We had thought this was a free service...??? Yes, we fixed it ourselves, after trial and error. We pulled out the ice bin and there is an arm that is moves back and forth beside it. It had frozen up. That is the ice crusher. Thaw it out and it is fixed. By the way, the above posting was not by us--ours stated that our ice crusher did not crush ice anymore. Instead, cubes came out...
Jul 12, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice Maker will not dispense ice cubes only crushed ice
sounds like the circuitry on your Cubed Ice button has malfunctioned. Contact the manfacuturer for a solution.
in the meantime, u can grab the Cubed ice manually.
hope this helps!
Jun 16, 2008 | Frigidaire FRS26R4A Side by Side...
Kenmore 55692 / 55694 Side by Side Refrigerator Logo
404 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
tootsie mason
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
