Question about HP PSC 1210 All-In-One InkJet Printer
Hpc4100 printer error message 'Remove and check cartridge on right"' Refer to printer documentation
  • 4 Answers
3 causes
1 faulty cartridge
2 dirty contacts
3 print carriage ribbon damaged
Rmove cartridge and rub the golden contacts at the back of the cartridge with a slightly damp (not wet) tissue. Re insert and turn printer off and on again
If this doen't work check the white ribbon inside the printer cartridge carriage in the printer (which touches the golden contacts on the back of the cartridge when it is inserted) for damage - it might have a pinhole in it where the metal pin holding the cartridge in place has pushed back through the white ribbon
If there is no damage and rubbing the cartridge contacts has not worked then most likely it is a faulty cartridge
Let me know how you get on
Posted on Nov 11, 2008
My J3680 keeps dis[playing "Cartridge Error:" "
Remove both cartridges, switch off then on, printer detects cartridge missing, install cartridges one by one & observe which one showing faulty, replace faulty cartridge..end..
Oct 07, 2011 | HP J3680 Officejet All In One Printer
Getting error message, "refer to
Try to check the Print Cartridges if they still have ink in them. or try to do a Semi-Full Reset. combo would be: - "print photo" + "red eye removal" buttons pressed together - printer will not ask you to enter the combo - release the buttons you pressed then - press "red eye", "print photo", "red eye" in sequence - scroll down or right until you find resets menu - press ok - scroll down or right until you find semi-full reset - press ok
- your printer should turn off, wait for 3 minutes before turning the printer back on
Mar 23, 2011 | HP Photosmart C5280 Printer
Hp officejet 4355 gives this message " cartrige error" refer to device documents for trouble shooting
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Mar 21, 2011 | Office Equipment & Supplies
Cartridge error refer device documentation troubleshoot
Remove the black cartridge and keep only the color cartridge in, and check the message. Now remove teh color cartridge and insert only the black cartridge in, and check the message. This should give an idea about which cartridge has a problem.
Feb 17, 2011 | HP Officejet 5610 All-In-One InkJet...
Cartridge error: refer to device documentation to troubleshoot
remove the cartridges and clean the metal contacts with tissue paper and put it back. if the problem continues check the cartridges.
Nov 03, 2009 | HP Officejet 5610 All-In-One InkJet...
I put in a cartridge and it is saying
check first if other cartridges works correctly and if do so just change cartridges with the store you just bought
Sep 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Just stoped printing;print cartridge problem
Remove print catrige and clean it with cotton cloth then refix it.
May 19, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Refer to printer documentation error message
I kept having the same problem as what was experienced by gobigforgod. What should I do ? Pls help.
Mar 26, 2009 | HP Photosmart C5280 Printer
HP Officejet 4355 All in One Cartridge Error
your cartridge may be faulty if you change cartridge and message display same problem so clean catridge block contact with soft cloth clean cartridge back side using student eraser if problem will continue so contact your hardware technician
Mar 27, 2008 | HP Officejet 4355 All-In-One InkJet...
HP PSC 1210 All-In-One InkJet Printer Logo
115 people viewed this question
Ben Johnson
