Question about Philips BLUETOOTH HEADSET Headset
Philips bluetooth headset loses connection.
I have a philips bluetooth headset that came with a pendant style receiver and a separate transmitter. It is about 6 months old and all of a sudden the receiver won't power down and it loses the connection every 5-10 minutes. It eventually comes back on after a couple of minutes,. When I charge the receiver up it flashes red and then green. It used to be solid red until it was charged and then both lights went out. The charge seems to last for days when not in use so I don't think it is a bad battery. I tried to take the battery out to see if that would mayb e reset it or something but it is wired in so no dice,. Any ideas? Thank you. Bob
  • 138 Answers
SOURCE: Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Posted on Aug 21, 2008
SOURCE: DVP642/37 Power light flashing constantly.....won't power on
This origional post has been up since June 2006. The answer(s) about the 1000mf capacitor are right on target and has helped people even up to today (Aug. 26, 2008). It worked for me and the following might help others.
First find the power supply board. It is the one with the power cord attached to one end (make sure you unplug all power first!). This power supply has about nine minature electrolytic capacitors in the output of the supply. There is a large electrolytic near the input (elecrtical cord). Disregard this one and go to the other end of the board. The 1000mf, 10volt component you are looking for is near the middle of the 9 or so capacitors on this end. It will probably be the largest in this group (because it has the highest electrolytic value of the group) and the board surface will have an I.D. number of C316 adjacent to it.
DO NOT ASSUME THAT THE CAPACITOR WILL HAVE ANY SIGN OF A BULDGE, DISCOLORATION, OR ANYTHING THAT WOULD IDENTIFY IT AS A FAILURE! In my case the replacement solved the problem but there was absolutely no signs on, or around the capacitor. After replacing it, I checked the old capacitor with a (ANALOG) multimeter. The test showed leakage across the capacitor. In other words it was still working but had a high resistance path through the capacitor. This is exactly what I expected because when I checked the output voltage of the supply to the other 2 boards, voltage was present but was reading about 1/2 of what it was supposed to. The markings on the front (output) edge of the board indicate a -24 volts between ground (pin 4) and pin 3. Mine was reading approximately -12 to -13 volts.
I hope this will help others. As a matter of interest, this is an electrolytic capacitor and you should notice that the component taken out is marked negative ( - ) near one lead. Be certain to install the new one with the negative lead in the same manner! Also, any replacement you might find with a higher voltage rating should be at least 16 volts but a 200 or 1000 volt rating will work fine. Although, the higher the rating, the larger it will physically be. You probably would not be able to physically install anything over 50volt rating. The 35volt rating seems to be very available and a very good choice. With regard to microfarad (mf) value, 1000mf are very common but a 1200mf to 1500mf in a power supply circuit will work fine. Do not use anything less than 1000mf. Hope this helps others. This is going to contiue for this Phillips product until they all die.
Posted on Aug 26, 2008
SOURCE: Pin number for philips SHB6100 aside from 0000.
yeah hedenram is right. my problem was that i was trying to pair something WITHOUT the headset in pairing mode. just switching it on doesnt put the headset in pairing mode and it will reject the 0000 passkey even if this is correct. it is vital when you turn on you hold the power button til it flashes red/green and then it will be in pairing mode and accept the 0000. the only way i found this was in the instruction booklet which i thought i had chucked away
Posted on Nov 27, 2008
rockfixya
  • 679 Answers
SOURCE: Connection problem for Philips VOX130 with other bluetooth devices
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select VOX130 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 31, 2009
SOURCE: red light flashes
This is a well known and very common problem with all Philips plasma tvs 42 and 50 inch. The problem is they used under rated capacitors in the power supply. If you have electronics experience or a friend that is, remove the cover and look in the back for malformed or leaking capcitors. Replace them and see if that takes care of the problem. The caps only cost $2 or $3 each, so the cost to try this is pretty reasonable although you might have an added cost of buying beer for your electronics friend. If this does not fix your problem you are down to replacing boards that can be purchased around $300 ea.
I have found my set will come on "finally" after I get the back of the set warmed up and the bad caps finally charge up. Hope this is useful.
Posted on Feb 27, 2009
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
Does the shb4000 pair with more than one device
Not at the same time, but after you paired it with one transmitter, you could pair it with another. Make sure the first transmitter is switched off, because as long as it is connected to a transmitter, it won't accept another source.
Dec 27, 2014 | Philips SHB4000WT Bluetooth Stereo Headset
Great sounding speaker, but nothing but trouble with the bluetooth. It appears that I can only have one device paired at a time. In order to connect another device, it breaks the current pairing. A
Yes this is a 'feature' of Bluetooth. (I have never seen the point of Bluetooth... Wi-Fi does everything it does, but better !)
It DOES usefully enable a phone or tablet to play though headphones or speaker and to use a headset 'cordlessly'...
Consider instead a 'Bluetooth Receiver' (under US $10 from China) connected to a FM Stereo Bug (Transmitter) - Then you can use any number of quality FM Radios (including phones with built in FM) up to 50 metres or so away...
example: http://www.ebay.co.uk/itm/Wireless-3-5mm-Stereo-Audio-Adapter-A2DP-Bluetooth-Dongle-Transmitter-Receiver-/141227224470?pt=UK_Home_HomeDecor_Accessories&var=&hash=item20e1cc6d96
Dec 10, 2014 | Marshall Stanmore Bluetooth Speaker
Changed battery and it doesn't detect transmitter. Everything else works and the transmitter gets detected by our treadmill, so I know it works.?
Transmitter Battery
The estimated average battery life span of the transmitter is 2500 hours of use. If you suspect that the transmitter battery
has run out, contact your authorized Polar Service Center for a replacement transmitter. Polar recycles used transmitters;;;
Dec 28, 2013 | Polar F6 Wrist Watch
I have nokia n95 phone. may i know the pairing code of for SBH650 for connecting
  1. Enter Pairing mode.
    • Slide the power switch on.jpg with pressing and holding [ talk.jpg ] to turn the headset on. The indicator light turns on blue and stays lit after flashing blue, red, and purple twice.
    • If you turn the headset on for the first time, it proceeds into Pairing mode immediately.
  2. Search for and connect with your phone according to your phone user's guide. (Bluetooth PIN: 0000, 4 zeros).
  3. i hope this helpfull
  4. if you think this helpfull, please rate very helpfull
  5. thanks for using fixya
Jan 24, 2011 | Samsung OEM SBH650 Bluetooth Stereo...
Hi, I purchased two units of logitech cordless
Your friend should be able to use the headset if your friend's computer has Bluetooth feature. THe computer will send and receive the Bluetooth signals with one transmitter/receiver like your computer does and then connect to the wireless lan with a different transmitter/receiver system on a different frequency. Just make sure your friend's computer has Bluetooth feature turned on and then setup the headset by the "pairing" process.
Jun 15, 2009 | Logitech Cordless Headset for PC & Mobile...
How can I receive bluetooth files automatically in storage card
There is a small application which does this for you.... very good app. here's the link:
http://www.freewarepocketpc.net/ppc-download-obexinboxex.html
Apr 14, 2009 | Computers & Internet
The Jabra A210 keeps dropping the connection between the devices.
My solution is to connect the jabra audio jack to the speaker output of my receiver. Jabra need it to detect a source. If the connection to the source is cut, jabra waits around 30 seconds and if nothing happend jabra stop the transmittion. I hope that helps.
Mar 13, 2009 | LG Jabra A210 Bluetooth Adapter for...
Jabra bluetooth adapter A210
hi,
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
Tips:
Jul 05, 2008 | Philips VOX130 Wireless Headset
Philips BLUETOOTH HEADSET Headset Logo
77 people viewed this question
Top Philips Radio Communications Experts
Computer Repairing
Computer Repairing
Dayton Computer
Dayton Computer
kiranbodapothula
Are you a Philips Radio Communication Expert? Answer questions, earn points and help others
