Question about Saniflo 013/005/007 Sanibest Toilet with Grinder Series Pump in White Elong
Water leak from turboflush saniflo
Hi
installed a 'turboflush' branded saniflo and no mater what i do i cannot stop a slight water leak and it seems to be from under the unit as there is no water dripping from the inlets,if i leave for a few days the floor is dry but run water from the basin and within minutes its becoming wet again,i cannot work out where the water is coming from has anyone else had a similar problem ?
    Scholar:
  • Saniflo Expert
  • 115 Answers
Check the piping, it might be a loose connection. Also you may want to replace the rubber coupling in between the side inlet and the sink drain. The rubber fitting might have a pin hole.
Posted on Jul 27, 2010
Water inlet pipe blows off when toilet is flushed
Posted on Feb 06, 2010
  • 145 Answers
REMOVE THE UNIT AND RUN THE WATER THEN TO SEE WERE THE WATER MAY BE COMIEING FROM
Posted on Dec 12, 2008
The saniflow is trickling and filling up bowl then flushes itself
You need to adjust the float. Or, you can buy the complete inexpensive float valve assembly at Lowes or Home Depot and can install it in less than 5 minutes. Turn off the water supply, drain the tank, sop up the remaining water in the tank or put a pan under the tank opening for the next step, remove the valve assembly and float and install the new valve assembly with the float included. Turn on the water supply and set the water level adjustment valve to about 1/4 inch below the stand pipe overflow drain. This is done by the float assembly. Turn on the water supply. This completes the change-out.
Oct 12, 2014 | saniflo"" turboflush toilet"
Turboflush T12 , when flushed pump runs but does'nt empty the pan,
the outlet is blocked or installed incorrectley, outlet frozen to great a incline, pipe to small, non treturn valve has debri on top of iot so fails to open fully on the pump start
Nov 04, 2011 | Saniflo & Saniplus& Macerator Pump
I have a turbofush P macerator and the pump no longer switches off automatically after grinding and flushing has occurred
turboflush uses a pcb mounted pressure sensor to switch the unit on/off. there is a small tube that connects to this unit. make sure that is ok and connected. otherwise its a new pcb i'm afraid. look online more info from saniflo-pumpshop.co.uk
Mar 17, 2010 | Saniflo & Saniplus& Macerator Pump
My turboflush macerator does not take all the
indicates that the unit may need cleaning /descaling. alternatively the 22mm pipework (outlet) may be partially blocked
Dec 27, 2009 | Saniflo & Saniplus& Macerator Pump
Hi there, i have got a problem with my turboflush; it seems that it struggle alot after flushing, even with a clean flush. it does make a grinding noise as well. it goes on for quite a while whereas before...
It really sounds like something that shouldn't be there is in the macerator/ejector. If you are not familiar with the internal workings, call the plumber who installed it. Best case scenario, it is just something that needs to be removed. Worst case scenario, the macerator/ejector and motor bearings are shot and need to be replaced.
Dec 21, 2009 | Saniflo & Saniplus& Macerator Pump
How to unclog the macerator - Saniflo TurboFlush P
First unplug the unit from the GFI, remove all the piping attached to the pump, remove the pump completely out the back of the toilet. Pry open the lid with a flat head screw driver, remove 2 screws in front of the pump and the motor and pressure chamber can be pulled out the top as one piece. Inspect the blades (on top of motor) also inspect the impeller which is at the bottom of the motor, you must turn the black pump cover plate counter clock wise to unlock it and inside there you will find the impeller. Also check the drain pipe for obstructions.
Aug 15, 2009 | Saniflo 013/005/007 Sanibest Toilet with...
Open Questions:
Saniflo 013/005/007 Sanibest Toilet with Grinder Series Pump in White Elong Logo
969 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
