Question about Baby Gear
Instructions for Delta Winnie the Pooh 3 in 1 crib
I lost my instructions for my crib and would like to convert it to a toddler bed. I looked for the instructions at the delta website, but I can't find it for this particular crib.
SOURCE: i need to know how to convert it to a toddler bed
The front rail just comes off and then the toddler is able to get in and out.
We did this with ours and it worked out great.
Posted on Nov 14, 2007
SOURCE: Delta luv crib hamptons 3 in 1 crib manual
I was looking for the same thing. My crib has directions on the board that the mattress sits on. It basically says to remove step 4, which is the rail that goes up and down. You slide it up a little from its bottom position and then the screw heads come through the slots that you see and then the whole thing comes off pretty easily. I has to push and pull a little to get the screws through but it worked fine. There is no additional piece that goes on, just stays like that and is stable. My son is very excited to give it a try tonight. Sort of a long way down though! Need to find some extra pillows for a safe landing! Good luck to everyone.
Posted on Apr 24, 2008
SOURCE: Toddler Bed Side rail for Delta Luv 5-in-1 crib
Try calling the customer service number (212)-645-9033. I have not called them yet to get the conversion rails for our Delta Luv 5 in 1, but I'm hoping that they will know more than Babies R Us!!
Posted on Sep 29, 2008
SOURCE: trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Posted on Apr 02, 2009
SOURCE: Transfer Delta Luv Crib (Poma) into a toddler bed
the instructions should be pasted onto the wooden board that the mattress is on.
Posted on Aug 14, 2009
Aug 08, 2009 | Delta Luv Delta - Baby Products 5-in-1...
Converting a crib into a toddler bed
what brand and model number of crib/bed is it?
Jun 13, 2009 | Delta Luv Delta - Baby Products 5-in-1...
Need Instructions For Delta Luv 3-in-1 crib Model No.4580. Trying To Convert To Toddler Bed.
I have the same crib and the instructions are on the bottom of the mattress board. Mine states to remove one side to make it into toddler bed.
Jun 04, 2009 | Delta Enterprise Capri 3-in-1 Crib
Trying to turn our crib into a toddler bed
Safety rail
Safety rail bolt
Mar 25, 2009 | Delta Enterprise Baby Gear
Lost manual for crib to toddler bed Model 8760H
Hi everyone,
I just went on to the Storkcraft website for Canada and found some installation instructions. There are instructions for the initial set up, for converting to a toddler bed, and converting to a daybed. Here's the link . On the right side there are 3 links for Assembly instructions. The first is the initial assembly, the second shows the toddler bed and daybed assembly, and the third is a complete installation manual. Hope that helps!
Erin
Nov 21, 2008 | Baby Gear
Lost instructions
that means it does turn into a toddler bed and the instructions for mine are also printed on the bottom of the support board for the mattress try flipping it over and see if your's does too
Nov 17, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Help! I have lost my directions to my Simplicity Aspen 4-in-1 Bed
Hi - you can see a video of the assembly on the following link:
http://www.simplicityforchildren.com/instructions/bassinet.asp
Also from that site you can request an instruction sheet from customer services.
Good Luck!
Jul 02, 2008 | Simplicity for Children 4-in-1 Convertible...
Convert to toddler bed
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here:
http://www.pali-design.com/index.php?path=customer_services&template=faq&section=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed
To convert a crib into a toddler bed you must loosen the two front gold bolts left and right side of the crib and remove the dropside (the front gate that goes up and down). After removing the dropside be very careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail)
To install a streight (toddler) rail loosen the two front gold bolts left and right side of the crib and remove the dropside, once you have removed the dropside replace with the streight rail. Always be very careful and make sure you tighten back your two gold bolts in the front.
Oct 14, 2007 | Pali Sabrina Crib
Baby Gear Logo
657 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
