Screen does not open to the maximum. There is two inches on each side. Some items cannot be seen because of this cut off and condensed size.
  • 42 Answers
Hello.,            try adjusting the settings in the monitor., if it does not wrk means... connect your monitor with another pc and check for the problem., if its a monitor problem means u can get it done from any service center...
Posted on Nov 11, 2008
What size should I get? Height 64 inches;32 inch width;26 inches deep.
The maximum size you get is determined by the space you have available after allowing for side and top ventilation which is critical to the functioning of the Refrig.
Allow at least 2-3 inches either side and 2-3 inches at the top if there are cupboards or shelving over the Refrig location.
measure out the maximum distance in depth you are happy with after allowing an inch or so clearance at the rear so you do not buy a unit that projects to far into the room space.
Then you can check manufacturer sizes and choose a frig brand that fits within that space you have measured out.
Nov 13, 2015 | Refrigerators
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Can't read HD-- I/O error
"Joecolvette" has probably got it right, I've seen this before. The HDD enclosure circuit board has a fault. Can be resolved by replacing the enclosure. Plenty on ebay, just ensure you buy one with the correct HDD interface (Sata or IDE).
Alternatively, if you have a tower with a spare port, you could take the HDD out of the caddy, install it in the tower as a "Slave" (check jumper settings) ensuring the system drive is set to "Master". Then you can check whether the HDD itself is at fault.
Apr 28, 2012 | Maxtor Computers & Internet
Icon short cuts doubled in size. How do I get them back on my desktop to normal size??
Windows XP Right click on an empty spot on your desktop and choose properties then click on appearance then click on advanced option, there you can see one tab named items select icon ,same tab right hand side you can select size of the icon(normal size-32), after that click on OK on both windows this steps should change your icon size.
Windows Vista or windows 7
Right click on an empty spot on your desktop and choose Personalize, now choose the first item on the list Windows Color and Appearance, and then click the last link Open classic appearance properties for more color options,
then click on advanced option, there you can see one tab named items select icon ,same tab right hand side you can select size of the icon(normal size-32), after that click on OK.
Shibi P G
Jul 17, 2011 | HP Computers & Internet
I install window 7 but my benq 15" lcd monitar's screen rosuation not competible. pls guide me how i increase the rosulation thnx
As for your 15" LCD BENQ Monitor, "1024 x 768" pixels is the Maximum Resolution
If you increase your screen higher than the Maximum resolution you get a black screen! because the monitor cannot support the resolution higher than "1024x768" pixels.
How to change your screen resolution Win 7-> Link
Here are typical resolutions for some popular screen sizes
19-inch screen (standard ratio): 1280 x 1024 pixels
20-inch screen (standard ratio): 1600 x 1200 pixels
22-inch screen (widescreen): 1680 x 1050 pixels
24-inch screen (widescreen): 1900 x 1200 pixels
Hope it helps.
Nov 22, 2010 | Computers & Internet
Blade length problem
Hedge trimmers cut using either a single-action, where only the top blade oscillates, cutting against the stationary lower blade, or a double-action where a pair of double-sided toothed blades that slide back and forth at a high speed so you can sweep across hedges in both directions. The latter are more efficient. Blade length Consider the size of the hedge you will be cutting to get the right length blade. The longer the blade length, the more area it can cover and the quicker it will get the job done. However longer blades also require more power and larger heavier motors so weigh up blade size versus ease of use. Blade lengths range from 14 to 30 inches with long blades of 22 to 30 inches providing extended reach for taller or wider hedges. Blade width The blade width indicates the space between teeth and the maximum thickness the trimmer can cut through, eg. 20mm blade width will be able to cut through a maximum 20mm branch.
Aug 27, 2008 | Bond Manufacturing 6-pieceUltimate Pruning...
Rca p56740bg tv
Most of the screen cover for sets older than 8 years have been discontinued,get the size of your screen leaving about 1/8 of and inch around the screen,you can get your local lumber or hardware store to cut pexie glass to fit,get velcro and apply to sides of screen to attach glass,make sure to sand any sharp sides before attaching.
Dec 31, 2007 | RCA P56830BL 56" Rear Projection...
Many ways to change the size of objects on the screen exist. Use the Dell QuickSet tool to change the size of icons and toolbars. Additionally, use the Display item in Control Panel to change the font size or the dots-per-inch (DPI) setting. Changing the DPI setting changes the size of all items on the screen. If the screen resolution setting makes items too small, the DPI setting can be increased to compensate.
Nov 16, 2007 | Dell A920 InkJet Printer
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
