Question about Panasonic NV-GS200 Mini DV Digital Camcorder
Red lines on screen when recording
Recently, when I have tried to record, red flashing lines appear on the lcd screen and through the viewfinder. They seem to centre around areas of light- if I record something very dark there are fewer lines. The sound is unaffected but the picture is completely unusable. Please help. I have tried nothing yet.
Important Notice
Digital 3CCD Camcorder
Panasonic has discovered a premature component failure with a limited number of PV-DV953 (2003 Model) and PV-GS200 (2004 Model) 3CCD camcorders, which may cause an abnormal camera picture (incorrect color reproduction, reddish, noisy image, etc). This anomaly is limited to a specific range of serial numbers listed below.
If your camcorder demonstrates the specific symptom and falls within the serial number range, Panasonic will repair the camcorder free of charge.
Please call the following toll-free number for assistance in receiving a free repair:
Panasonic Call Center: 1-800-973-4264
Model # Serial Number Ranges
PV-DV953 (2003) E3Hxxxxxx, F3Hxxxxxx, G3Hxxxxxx, H3Hxxxxxx, I3Hxxxxxx, J3Hxxxxxx, K3Hxxxxxx, L3Hxxxxxx and A4Hxxxxxx
PV-GS200 (2004) C4Hxxxxxx and D4Hxxxxxx
Posted on Dec 16, 2007
    Problem Solver:
  • 19 Answers
Dear sir, Please check Live picture, If Live picture is not ok, Then the CCD is defective. If you are playing cassatte also Red lines appearing means then it has to check ( problem may be LCD Or View finder) Thanking you & best of luck Udupi
Posted on Nov 22, 2006
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
No image on LCD screen
It sounds like you're receiving partial information on the LCD screen and that the image sensor isn't sending information to the screen.
If you know the sensor is working by recording some video on an SD card and being able to view the recorded video on your PC, then there is a disconnect between the LCD and the image sensor.
If you are not recording video to your SD card and only get black images or no files, the image sensor is damaged.
If you are recording video, but no image appears on your LCD for internal viewing/playback, you can try a firmware update if one is available from www.insigniaproducts.com, but this is a discontinued item so there's not much available for support.
Hope this helps!
Apr 25, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
The image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Red power light flashing on and off
the same thing happens to me! idk how to fix it
May 05, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
No picture on lcd & view finder
PLease see http://www.fixya.com/support/t131881-sony_cam_recorder_wont_record for more information on this i have had the same problem, faulty CCD image processor chip.
Apr 01, 2008 | Video Cameras
LCD screen stopped working
sounds like the LCD screen viewfinder may have been twisted or accidentally catched or got hooked or snagged on on something at one stage and pulled something, if the screen went yellow it means the three wires going to it are possibly broken or the small white clip was slowly coming undone inside the Viewfinder for the red and green to no longer work to complete the image also indicates why the buttons on the viewfinder are not responding, try twisting the viewfinder very lightly whilst on, but most likely the small white clip holding the wires has come off at the elbow inside the camera
Apr 22, 2017 | Sony Handycam DCR-HC21 Mini DV Digital...
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Red Screen
Since this is being recorded it is not a problem with the monitor or viewfinder. I believe that it is a problem with the imaging chip or the circuitry immediately after the image block. It actually sounds like a bad solder joint. If you are very good with tools and soldering, have magnifying glasses and a steady hand, you should be able to repair this. If you are not familiar with the repair of camcorders (and there are many tiny pieces to keep track of) there is probably little you can do to solve this problem. If you go to this website http://www.videotech.com for the price of shipping you can get a free estimate or you can get an estimate online at http://www.camcorderrepair.com I would think that the cost to repair this should be reasonable. Good luck.
Jun 12, 2006 | Panasonic NV-GS200 Mini DV Digital...
Panasonic NV-GS200 Mini DV Digital Camcorder Logo
201 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
