Question about Dryers
Broken belt on Hotpoint Aquarius dryer tdl30p
Hi
The belt on my dryer has broken. I have taken the top off the machine and can see where the old belt went. I have ordered a new belt but not sure of the next steps. Any help would be great.
  • annettejc Apr 05, 2009
    my tdl52p has no tensoner,i have the correct belt but there doesn`t seem to be enough slack to get it onto the motor pulley
  • 43 Answers
You neen to access the machine from behind you will have to remove the back panel and the tensioner pulled back you should be able to work out where it goes put it around the drum first though its easier
Posted on Nov 11, 2008
Hotpoint Aquarius dwf33 is not starting cycle! Making a clicking noise and a whiring noise.
You may have a broken dryer drum belt, pull the back off the dryer and look inside to see if that is the case.
Feb 09, 2017 | Hotpoint Washing Machines
Hotpoint aquarius tvm570 dryer
Either the belt is broken or possibly the motor starter has failed. Very often the belt. Be warned though, modern day tumble dryers use stretch belts that can be very difficult to fit.
Oct 18, 2013 | Hotpoint Dryers
My hotpoint aqaurius WD420 is not drying.
Could be stat or heater .Remove the top cover, and you will see the heater manifold on the right side of washer drum.
The element and stat/s are located on the top of the manifold box.
You willneed a meter to test with, also check for broken wires.
Feb 05, 2010 | Hotpoint Aquarius WD640 Front Load...
HOTPOINT AQUARIUS RANGE DRYER DRUM NOT SPINNING UNLESS YOU OPEN DOOR AND GIVE IT A PUSH
belt tensioner could have a broken spring on it or motor is going bad. It could be a problem with the belt being stretched or oily but probably not- check first.
Dec 03, 2009 | Hotpoint TDC32 Electric Dryer
Door hinge is broken on my hotpoint aquarius
Get the model number off the unit and go to sears parts on line. Good luck
Dec 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Banging washing machine on spins
Hi. I don't know if your problem has been sorted yet, if it has not ,then it sounds to me llke the concrete balance weight is loose or broken
There are 2 of them, one in the top of the m/c, and one at the bottom, if either of them are loose, then that is your problem.
If loose, can be tightened up, if broken away from the drum then you have a major problem
Nov 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Why wont my washer dryer empty the water...???
If the machine fills and agitates but does not drain, something is probably wrong with the drain hose or the pump. The fact that the washer fills and agitates tells you that the motor works and the belt is okay (though some units have a separate belt for the pump and direct-drive washing machines don't have belts). 1) Be sure the drain hose isn't kinked. 2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The water pump may be broken or clogged with a small article of clothing or the controls may be broken; call an appliance repairperson. courtesy "nagev"
Oct 24, 2006 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
235 people viewed this question
Top Dryers Experts
