Question about Philips PCRW (PCRW404) CD-RW Burner
Cd drawer opens and closes by itself
CD dawer opens and closes by itself
    Champion:
  • 208 Answers
The sensor that tells it when door closes under door theres a guide that flips a slide switch as it goes in is failing. bad hardware!
Posted on Nov 13, 2008
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
Cd rom door opens by itself
If the drawer does not detect that it has completely (100%) come to the "closed" position, it will open itself up, indicating that you should remove any object that is preventing the drawer from reaching the "100% closed" position.
Aug 30, 2013 | Compaq Computers & Internet
Player will not play a loaded CD and No CD message comes up Also CD drawer opens and shuts on it`s own !!!
the tray opening by itself could be a faulty limit switch on the tray mechanism
the switch tells the system if the tray has reached the open or closed position.
if it closes then opens itself then this is the most likely
check that first
could be closing then opening without actually loading due to the switch
you will need to open it up to find the switches
usually at the bottom front were the tray goes in
darren
May 28, 2011 | NAD C542 CD Player
Door to load cd's wont open or close without help.
hello i have had the same problem with my 5 cd changer,i way i solved this was to turn the player top slide down then do this care fully ,shake it gently and see if a cd came out of it, groove sit in the player.if you hear a rattle than there is a stray cd in the device. you have got to shake the cd to the front of the cd dawer to take it out with a thin ruler or a butter knife but be care ful with the knife preess on the open button wale trying to slide the butter knife between the stuck cd and the inside of the cd sit cation be care.
Apr 25, 2009 | Audio Players & Recorders
Cannot open cd drawer
If it will not open by itself, open up a small paperclip and push it into the little hole on the front of the cd rom. This will release the latch, and allow the drawer to open
Mar 16, 2009 | Gateway Computers & Internet
DVD had a jammed disc. Got it out but drawer stays open
You broke it. Spend $30 to buy a new CD/DVD reader/writer.
Dec 21, 2008 | Compaq (224130-001) Internal 4x CD-ROM...
CD drawer will not open or close
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
Jammed cd drawer
The best solution is to take off the top cover. It's easy to remove with, I believe, four screws. The carousel is located right underneath the cover, so all the CD's will be exposed. However, I don't think that this will solve the problem of not happening again, since this seems to be a problem with this particular model.
Oct 05, 2007 | Panasonic SC-HT740 System
Philips PCRW (PCRW404) CD-RW Burner Logo
519 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
