Question about Car Audio & Video
Stop kenwood KDC-mp239 loosing radio settings with ignition off
I have been advised to cross over the power wires on this radio cd player when fitted to a European car (Holden Barina) to prevent the radio station settings from being dropped when the ignition is switched. This seems electrcially dangerous however when the wiring is matched colour for colour and the ignition is switched off, the tuning for the radio stations is lost. Any comments?
  • Anonymous May 07, 2009
    I have a problem with KDC-mp239 we did the wiring properly but there is no power
    Novelist:
    Champion:
  • 218 Answers
You have two power leads bringing battery power into the radio. One is switched off when the ignition is off and the other power lead is always on. That second one is the one you may have wired wrong. You need to check that one out to make sure it stays on when the key is turned off. Good luck.
Posted on Nov 11, 2008
Kenwood KDC-319 CD Player Logo Problem with KDC-319 CD Player installed a kenwood kdc 319 in a 04 chevy malibu when i have car off i turn deck on an my cars dash board lights turn on Posted by A
I would start by disconnecting the radio and hooking it up right,the power should go through the ignition switch.So that when you turn the car off the radio will go off and to hear it on again you have to turn the key to accessory or start it.That might take care of a few of your problems.
Jun 25, 2012 | Kenwood KDC-319 CD Player
INSTRUCTION MANUAL FOR KENWOOD STEREO KDC-MP239
  • Hi, i can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 22, 2011 | JVC Car Audio & Video
My Kenwood Excelon KDC-X559 does not power on at all. I know that it is getting power though. You can insert and exit cd's from the unit but that is all it will do. Screen does not show power at all. Is it...
are you sure you have power going to the red wire? the red wire needs to be connected to a switched (ignition) power source. the radio will not work unless both the red and yellow wires are getting power.
Mar 06, 2011 | Kenwood eXcelon KDC-X559 CD Player
When I Installed the Radio It Started to get hot on the back side of it so i disconnected it.Why did it get hot.
could be bad ground or you crossed the yellowwith the red wire. yellow is battery red is ignition and you usually dont use the other ones unless its a newer vehicle. also these ones have 2 blue wires 1 power ant and the remote lead
Sep 13, 2010 | Kenwood KDC-X589 CD Player
Kenwood kdc-mp239 car stereo overheating
Did you change the speakers, usually this happen because of the Ohms. Let me explain you, The factory radios are usally 8 Ohms and must of the aftermarket speakers are 4 Ohms or less so if you put 4 Ohms in a radio designed to work with 8 Ohms of coures is going to get hot first and them you burn it out.
Jan 04, 2010 | Car Audio & Video
Call constantly cuts in
you must of traped a wire when you have fitted the head unit to the car when you have pushed it into the dash or the call wire is going to earth on something behind the radio in the dash hope you fine it hope ive help you let me now how you get on
May 29, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Got a new Kenwood KDC-128 car radio recently, fitted it but the radio presets would not stay when the ignition was turned off. Then it stopped working altogether and I noticed the 10amp fuse at the back...
you need to hook the yellow wire off the back of the radio up straight to the battery this keeps memory power to the head unit then wire the wires in color coded sequence red to red black to black so on and so forth if this doesnt fix it you might want to think about replacing head unit
Jan 02, 2009 | Kenwood KDC-128 CD Player
Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
Nov 21, 2008 | Kenwood KDC-MP235 CD Player
Installing kenwood kdc-mp238 in a 2001 dodge ram 2500 quad cab
No ur radio is fine to fit the wiring harness into ur dodge the wiring has been crossed so it wont work, if u go 2 the Kenwood US site and down load the KDC MP 228 manual it has a good wiring dirgram and with a bit of work u can work out what goes where :0 Hope this helps
Oct 11, 2008 | Kenwood KDC-MP228 CD Player
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Car Audio & Video Logo
404 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
