Question about AOC 5 GLr Monitor
Motor ALWAYS on with Sony WM-D6C?
Hi, I have just recently found one WM D6C in a pawn shop, hoping to replace my now dead WM-D3. I do not know much of this machine, besides its normal functions (first use and never seen the manual.) The machine of very early revision (1st I think: 87XXX.) The first thing I noticed when I added new batteries is the motor spinning (without anything engaged). I found the Walkman is able to play my IEC 2 tapes well, and all other functions work (pause,dolby, etc) and responsive to ''speed control''. I believe this means the servo circuits are fine?
I noticed when I took it apart to check the rubber belts and flywheel that the motor is purposefully disengaged from the flywheel. So is it possible that the machine was designed to have motor continuously run?
Please tell me if this is normal before I start hunting for schematics and tracing the circuits.
  • cpplinker Nov 11, 2008
    Sorry wrong topic due to bad browser redirect. Please delete. Thankyou in advance.
My sony wm-d6c appears to be running at double speed can I fix this easily
Your set is running wild because the motor has lost the regulation.Hence you will need to replace the motor. It is also possible that the belt had jumped and got into the large end of the pulley to make the capstan spin higher. So remove and check both of these sectiions and confirm. Hope this sorrt yourr fault.Good day
Jun 28, 2010 | Sony Walkman WM-D6C Personal Cassette...
Who can I send it to for maintenance/repair?
Get in touch with me and describe the problem. I have repaired many d6c and high-end Walkman and, when possible, increase the performance. doctor.walkman @ gmail.com
May 14, 2010 | Sony Walkman WM-D6C Personal Cassette...
My Sony Walkman Professional WM-D6C will turn on but the take-up spindle just slowly inches the tape along in short bursts, not a continious action.
Contact me at my email doctor.walkman @ gmail.com, I'll ask you some questions and some photos of the WM-D6C in his possession. We will solve the problem
Apr 23, 2010 | Sony Walkman WM-D6C Personal Cassette...
While trying to rewind or fast forward, it stops before reaching the end, and I have to restart it.
Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Dec 10, 2009 | Sony Audio Players & Recorders
Motor is ALWAYS running on this thing?
No not normal motor shuts off when not in play or other drive functions! we repair that model! want to sell it?
Nov 11, 2008 | Sony Walkman WM-D6C Personal Cassette...
Tape fails to return to cassette when cassette removed.
I'm an repairer of electronic and micromeccanaca I have repaired many walkman analog (WM-D6C, wm-dd9, etc.. Improve your performance if required and if possible) and many like dat walkman Sony TCD-D3. I just started to repair even for those who come out of Italy. If you would contact me to explain the problem better I'll try to help. Email: doctor.walkman@gmail.com Sono un riparatore di elettronica e micromeccanaca ho riparato analogico walkman molti (WM-D6C, WM-dd9, ecc. Migliorate le prestazioni, se richiesto e se possibile) e molti come dat walkman Sony TCD-D3. Ho appena iniziato a riparare anche per chi si trova fuori d'Italia. Se vuoi contattarmi per spiegare meglio il problema cercher? di aiutarti. Email: doctor.walkman@gmail.com
Jul 29, 2008 | Sony Walkman TCD-D100 Personal Cassette...
WM-D6C Battery holder
Because of the age of the unit, Sony will not carry that part. However, keep an eye on E-bay and yard sales and thrift stores and hopefully you can pick one up real cheap. Good Luck
Oct 29, 2007 | Sony Walkman WM-D6C Personal Cassette...
AOC 5 GLr Monitor Logo
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
