Question about Vehicle Parts & Accessories
Reset of immobiliser on a renault traffic
I disconnected the battery and when i reconnected it the van will not start
Reset oil chance for renaulr trucks please!
Posted on Jul 07, 2009
How do I get my 07 Iveco daily to start as I changed all the fuses as I had blown the wiper one and now the immobiliser does not let me start it.
Try starting from scratch, disconnect battery for a few minutes and reconnect, ECU are usually reset and it may clear this default in your immobilizer. FREE-PPV.com
Apr 03, 2016 | Cars & Trucks
Renault Traffic immobiliser fault. When I turn the key the red dot in the middle of the dash is still on solid, not flashing and the van turns over but won't start. I have changed the fob batteries.
Undo the plastic casing around the ignition.
Its only around 4 screws easy.
look around the barrel where you insert the key, there should be a black plastic ring around 3 inches down the barrel this is the key reader its not fixed so twist gently and slide up the barrel as close to the key as the wires attached will allow.
then try starting, if it works then the transmitter in the key is most likely deteriorated . if it works its only a quick fix and could deteriorate in time.
a new key and coded from Renault is £300 with no guarantee that its not a different fault so look at buying one of ebay and get that paired to the immobiliser.
there is another way of bypassing the immobiliser by removing a ball bearing in the fuel pump a bit more complex.
Feb 04, 2016 | Renault Cars & Trucks
Renault kangoo 1.5dci van will not crank no immobiliser light flashing and starter motor just been replaced and to reprogram the key code do you hold the lock or unlock button on the centre consol
its probably a break in the loom between the battery and starter motor, if you are sure it isn't the immobiliser, try running a live straight from the battery to the starter, MAKE SURE THE CAR IS NOT IN GEAR!! otherwise you could have a nasty accident, If the starter turns and the car starts then you know its a wiring problem, if the car doesnt start and was working before then it will be the immobiliser, as for programming the key, all that is for , is the central locking , the immobiliser chip in the key can only be programmed with specialist equipment
Sep 06, 2014 | Cars & Trucks
Teft system on how do i disconnect the system
ive had this problem with another make of car before, the immobiliser was stuck on stopping the car from starting, reset the immobiliser by disconnecting the battery for a couple minutes and reconnecting it. good luck.
Apr 13, 2014 | 1998 Ford Mustang
Will not start
Most likely something not correct with new switch.
Nov 23, 2017 | Renault Cars & Trucks
Reset computer after service renault master
Try disconnecting battery for about 15 minutes and then reconnect,this should allow all computers on your vehicle to go to sleep and will reboot when you reconnect.Not a guarantee fix but tends to work 9 times out of 10.apart from this some thing may have been disturbed during the service,and will require fixing first.you may have to re enter the radio code so be sure to have that code at hand.Good luck.
Jan 03, 2014 | Not available Renault ING Racing Jacket...
Micra immobiliser not turning off
try using a scan tool to reset the ECM
having a battery disconnect for any length of time can corrupt the CPU program in the ECM
Nov 24, 2017 | 2002 Renault Clio
When i use wipers in intermitent mode the timeing
First rewire the immobilizer to work properly ,on the ignition .
Check that the wiper motor and wiper linkage is in proper sync,and or adjust
Mar 07, 2010 | Nissan Quest Cars & Trucks
Immobiliser problem problem with decoder ring
i got a r reg scenic and i cant get the immoobiliser off
Sep 11, 2009 | 2000 Renault 181
Hyundai Lantra Immobiliser
you have an override toggle switch hidden somewhere under dash youll have to search for it.
Feb 24, 2009 | 1997 Hyundai Elantra
Vehicle Parts & Accessories Logo
2,069 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
