I want surrond sound from my HD TV to my Motorola Digital Cable box with my Yamaha speakers via Digital Coax Cable how do I do this?
    Scholar:
  • 131 Answers
YOUR GOING TO HAVE TO BY A SURROUND PROSSESER
Posted on Nov 13, 2008
No sound from rear speakers with TV and DVD player
You also have to connect a SPDIF coax or optical from both the DVD player and from the STBox into the digital inputs on the rear of the receiver. And select them with the remote control.
Apr 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
No surrond sound
TV's are not sources of multichannel audio. The best you'll get is stereo analog. Get the best TV-related audio from the same source the TV gets it - in this case the Cable Box.
Feb 28, 2010 | Audio Players & Recorders
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
Cant wire theatre system right,only get surr. on dvd
Do you have a High Def cable box and Tv? if so you would use and HDMI cable from your cable box to your tv, then run an optical audio or coax audio from your cable box to your surrond system. Depends on which plug you have on both for the audio portion.If you dont have HD tv than you would run cable wire from cable box to tv then run red and white audio from cable box to surround system, to listen to it you would select aux channel.
Hope this Helps.
May 01, 2009 | Audio Players & Recorders
Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Mar 19, 2009 | Yamaha RX-V463 Receiver
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
Sound cuts out- cable tv
I had the same problem when I installed the new HD Comcast cable box (DCH3200), initially with my CRT through RF, then with my HDTV through HDMI. Problem solved when I replaced the box with the Comcast RNG110 I got from my local Comcast. It is a neat miniaturized box and it works extremely well on HD. There is no power switch on the box so before activation do not forget to put it on with the remote (cable, power, the green light will come on).
Aug 09, 2008 | Sony STR-DE595 Receiver
Setting up Cable with HDMI
Yes, the firmware on your hdtv box has an old firmware, I switched my old hdtv box with a newer one box and the problem was solved. It seems that it can't work if your hooking up with DVI to HDMI cable to your receiver to tv. Your hd box must have an HDMI out otherwise it causes problems. I also have rx-v661 and i finally hooked up everything HDMI to the receiver and then to the tv and it was having the problem you speak of. After I switched out the hd box for a newer one everthing worked fine.
May 13, 2008 | Yamaha RX-V661 Receiver
Surround sound 5.1
Does your rca cables go to a surrond sound amplifier or directly to the tv. The tv only has two speakers.If the signal is sent to a seperate receiver it must have a lisyen mode then set to 5.1 surround. The digital optic cable should go to receiver first.
Good Luck
big red
Feb 24, 2008 | Audio Players & Recorders
42 people viewed this question
 Grubhead
Grubhead
