This types of problems regularly occurs in epson printcartridges.as there is a ink pulling pipe in the printer to keep the ink in the cartridge to flow fluently.that pipe sometimes pull much ink then required and makes the cartridge empty and so it shows the cartridge empty or stops printing ink due to less ink in the cartridge for printing.and this happens.insert new cartridge again and it will start printing.but this problem can occur again.also get your printer serviced before replacing the cartridge again.
advise : go for hp printers if you want to avoid this kind of problems further.
thanks.
This may or may not work on your model
"Press and hold the paper feed, paper switch and the power switch.
Once
the power light and paper light flashes twice and the other lights are
flashing release the paper feed and paper switch "and then press the
paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
The Protection Counter referred to above prevents you from printing once the printed pages counter reaches a predetermined threshold.
If this doesn't work, let me know.
Regards,
Worldvet
Would you be willing to work on this problem so more until we discover what oddity is happening to you?
I'll work with you and may bring another expert friend of mine to confer on your problem.
I'm not ready to give up on this problem if you're not. The problem we have as experts using email is getting to the root of an issue. It usually takes more than a few emails to say the least. I was taking a shot in the dark with what I offered to you which is a reset trick. There are others we can try so we can unglitch your printer.
Regards,
Worldvet
