PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Dell Inspiron 5150 won't boot
By steffp01 on Nov 11, 2008
When I try to boot my laptop, it starts to boot ok then a few seconds later it stops and I get a green flashing power light and an orange flashing battery light. Does anyone know what I need to do to fix it?
Thanks,
Steff
Comments:
Nov 11, 2008
- I get the lights whether the battery is in or not.
Nov 11, 2008
- If I try without the extra RAM, it no longer does the flashing lights thing, it just waits a couple of seconds and turns itself off.
Nov 12, 2008
- I now get the same two flashing lights with no battery and no extra RAM installed (I've no idea how you access the RAM it came with).
Same Problem
Mar 04, 2009
-   My 5150 won't boot either. When I push the power button, the fan starts to spin and the power light comes on solid green for a few seconds. Then, the fan goes off, and the power light just flashes green about every 3 seconds. If I push the power button, the power light goes solid green for a few seconds, then goes out. If I push the shift key while the power light is solid green (before it goes out), the fan comes on constant, the power light flashes green rapidly and the battery light flashes orange rapidly. When I create this situation with the shift key, the only way to turn off the laptop is to pull the power plug and take out the battery. Does this give any more clues to how to fix this problem?-   leo5777
Feb 20, 2009
-   Exact same - flashing green power and amber battery lights - no response in any other way.  Battery out doesnt do anything.-   Guest
Feb 19, 2009
-   I have the same problem... I already take out ram, hard drive, battery, wireless card, and is still doing the same flashing lights...-   Guest
Feb 16, 2009
-   Dell Latitude 100L won't boot. Green power light and yellow battery light blink nonstop. Tried different RAM, hard drive and have taken out the battery. Still just flashing lights and won't start up.-   g4tom
Solution #1
posted on Nov 11, 2008
Somewhat Helpful)
chrlygrn
Rank: Wiz
Rating: 83%, 72 votes
have u checked the ram and made sure its functioning properly
Was this helpful?
Yes
No
Solution #2
Not Rated)
chrlygrn
Rank: Wiz
Take out the battery. that hapened on my inspiron 3800
Comments:
Nov 11, 2008
- If that's the only ram chip then you probably have a faulty ram chip. If you have an extra one than you can try it to see if it works. or borrow one from a friend.
Here is the ram your laptop should take. DDR2 - PC2100, PC2700, PC3200
You can buy that ram from (all below are links)
future shop,
best buy
factory direct
good luck
Nov 12, 2008
- there should be a compartment on the bottom that snaps off or screws off.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area... (More)
Answer
what is the problem of my HP laptop is going to blink2x his display in screen?
Answer
bios screen appears at start up how to stop this also won't connect to internet
Answer
we have error in IBM Thikpad No 19990302 19990304 19990305
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
