Question about Plumbing
Basement flooding through sumphole
I recently inherited my parents house. Several years ago an oil spill occured in the yard, alongside the house, on the driveway. An oil company mistakenly deliverd oil to the wrong address. All the soil on that side of the house was dug out as it had to be burned because of the environmental impact. The soil around the house has a high clay content and when the hole was backfilled, much to my late fathers annoyance, instead of using weeping tile and clay, gravel was used to do the backfilling. The oil company that was responsible for the spill refused to do anything further to repair the yard. Ever since, when the rain gets very heavy, the basement floods through the sump hole, which by the way is located not more than six feet or so from the spot that was dug out. Sometimes up to about three feet of water or maybe a little more. Having taken over the house, I also have taken over its problems. Is there some way that would be inexpensive, that I could stop this from happening any more. I had hoped that maybe paving the driveway might be a solution as the driveway goes right up to the foundation. Or perhaps another pump as a backup to the sump pump. It is a very small house and the furnace, freezer and the washer and dryer are in the basement. I would also like to finnish the basement to take advantage of as much space as I can. Do you have any suggestions that I can try to stop this from happening anymore? I am on a very limited budget to get this looked after, as this is only one of many problems that I have to deal with on this property Thanks very much.
Sincerely,
Lorna maclean
    Scholar:
  • 61 Answers
Okay here 4 solutions but they both going to cost .....
1. the clay they dug out was to keep the water from entering the building and when they put in the gravel that only filtered the water.....
try one of these:
1. if your yard is big enough to redig you will have remove what they installed out and redig a new area that has clay and have it repacked near the house that was your sealant..
2. you will need a waterproof sealant or liner install on the side of house..
3. have a concrete slab poured against the house but sloped away from house......
4. go get a waterproof liner like they use for ponds and dig the yard down and away from house and lay the liner against the house about 2 feet of the liner and the rest sloping away from house then refill on top of liner but not sure how long that will last because it will deteorate but not too soon...
that clay that was removed was your sealant the gravel that is there now acts like a filter only to keep out debris but let the water to still slip through....
and drylock paint will hold for a min but the water needs to redirected away from the house
Posted on Nov 12, 2008
    Problem Solver:
  • 17 Answers
Hi this is a new one to me.
Concrete has been used in so many aplications that it might just work.
O.K. this is how i got to get a couple of pools and spars sealed. 1 part cement and 10 parts water even able to deliver it by a bycicle pump. Sets as hard as any other cement just takes an extra couple of hours but moves like water.
Hope this helps.
Alistair
Coleman furnace. Why no heat?
Oil or gas? What model t-stat? Any recent events like household power isues, t-stat replacement (or needs/replaced batteries), basement flood, home renovation? To state the obvious, it's either not receiving a call for heat (controls,wiring) or not sending (t-stat or wire).
Apr 09, 2016 | Heating & Cooling
What would cause my shop vac series90pn to quit working while picking up water
The best thing for a basement that is vulnerable to flooding is a small sump with a permanently wired automatic submersible pump in it. Such pumps are relatively cheap and available in many qualities.
While such an installation will not keep a basement dry it will ensure the water level rises only enough for the majority to flow into the sump and be pumped away without you needing to do anything.
Wet vacs of my experience either have a float valve to prevent water ingress into the motor or a switch to cut off the power if the level rises too high.
Many such vacs have a powerful motor generating much heat and are only suitable for fairly short duty cycles. When used continuously the internal heat build up can distort plastic and melt thermal safety fuses.
It is impossible to guess what the trouble might be and that will only be revealed by checking. With vacs the first suspect is the power cord and the second is the switch...
Jun 26, 2014 | Shop Vac Vacuums
Hi; I have a Skil hedge trimmer model 518H2 that got under water when the basement flooded - now does not work - can it be fixed - how - or do i just buy a new one; Thanks sawent under ,,erq Kil
Remove spark plug and allow everything to completely dry. Check oil, if water in oil, replace oil. Heat up plug with a torch or lighter to get rid of any moisture. Then reinstall. Fresh gas should do the trick.
Jul 04, 2012 | Garden
My basement flooded 2" or
If the heater was flood by the high water, it not safe to operate until a qualified, professional service person has inspected it and repaired it. IF it can be repaired. Water reeks havoc on gas appliances. Stop trying to light it!
Mar 11, 2011 | Heating & Cooling
Gets stuck in drain phase, spin cycle working too hard, flooding
I know that this isn't what people want to hear in situations like yours, but...that definately is the quality of GE. With everything you've described...its' going to cost about 2x what you paid for it between diagnostics, repair & labor. I'd start shopping for anything with a Whirlpool name. Over the years, GE has had MAJOR KNOWN PROBLEMS with their gearcases (transmissions). My parents had a HOTPOINT and it lasted three years and one day I went down into the basement and there was oil on the floor. But anyways...I'd say it's a lost cause. It sounds like it was made on a Friday. Good luck to you, and let me know if I can help you again! God Bless and Merry Christmas!!!
Dec 17, 2009 | GE Washing Machines
Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Water backing up into my basement ejector pump during heavy rain
I have seen this problem several times before. The ejector pump should be in a separate crock in the ground by itself. Someone has installed it in the crock that is meant to pump out drain water. Probably the result of adding a bathroom in the basement. You need to bust another hole in the floor and install a separate crock to solve this problem correctly. If it just started happening go outside and look at he gutters to make sure water is running away from the house and not up against the foundation.
Please rate if this helps-
Mar 24, 2009 | Zoeller E282 Nonautomatic Waste-Mate
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Plumbing Logo
248 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
