Question about Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat
Boiler whining noise
I HAVE A HEATLINE COMPACT BOILER AND IT IS MAKING A
WHINING NOISE ALSO IS THERE A SPECIAL KEY TO BLEED THE RADIATORS ON THE SAME SYSTEM
  • robsmith852 Nov 25, 2008
    gas boiler
  • jim3078 Jan 10, 2009
    my boiler whisles at 135 degrees . what can it be?
  • 104 Answers
Electric boiler- or other ?
Posted on Nov 11, 2008
Loud noisy boiler what's wrong with it ?
Hi. I'm not an expert but most of my boilers in the past get noisy when they get air in the system. Underneath your boiler will be an inlet tap to top up the sysem with water. Make sure you bleed all of your radiators of air till they squirt water then keeb topping up the system and bleeding till no air remains in any of the radiators. There should be a pressure dial on the front of your boiler and there is usually a red fixed needle which shows what the opperating pressure is. I would do this before anything else and see if this solves the problem. :-)
Apr 29, 2013 | Water Heaters
Glowworm boiler making noises
You're probably getting what some call gurgling sounds because there is air in the system. You need to bleed the air out at all bleed ports starting with the lowest in the system and ending with the highest.It won't hurt if you do that process a couple of times. Once all the air is out, you should have a normal convection flow of water through the system. - Good luck!
Jan 30, 2013 | Bosch Water Heaters
Vaillant boiler ECO Max 824E F 20 error
Did you bleed the air from the pump ? Sounds like a air lock
Jul 14, 2017 | Water Heaters
My boiler lights up,stays on for 1 minute then cutts out...
You could check the flame sensor is clean and the connections are tight . check the pressure switch as well. also get the over heat could be shutting off too soon ,
Check the rads for air lock ,
May 11, 2017 | Water Heaters
Hi. my heatline vizo 24 boiler not working
overheat stat or fan best of luck
Oct 13, 2009 | Water Heaters
Heating pressure gauge goes up
yes tami
there should be a pressure rellief valve fitted.
it also sounds like the heat exchanger is blocked if the hot water is not as good as it used to be and the boiler reaches temperature too quickly then there is scale in the heat exchanger and needs to be cleaned or replaced
Mar 27, 2009 | Water Heaters
Very Hot water coming out of overflow pipe
Is your boiler heating your domestic hot water if so i would turn water off to water maker and see if your boiler pressure stays down below 20 psi. If so water maker is bad. The other thing that could cause this problem would be the boiler pump is out.
Jan 22, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Oct 08, 2008 | Water Heaters
Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat Logo
1,357 people viewed this question
Top Protech Systems Water Heaters Experts
Paul Carew
Donni Steen
Are you a Protech Systems Water Heater Expert? Answer questions, earn points and help others
