Question about Watches
Grandfather clock doesnt seem to be ticking and pendullum wont swing
I have a grandfather clock and it new but I don't have the instruction to set it right ,,,but my clock if from Black Forest and # 86 I think the name is herenk or kermk ,or kerenk ,I can't read it right ,,, Please help ,,,thanks
Posted on Jul 17, 2013
The clutch on the hook that the bob swings from has probably been bumped and changed the cruch position,take the bob and move it by hand from one side of the waste ,then do the same thing in the opposite direction,then try to start the bob to swing.
Don't get carried away when you start it up,too many people do thes hard and that will sometimes cause the clutch to slip.
Posted on Mar 29, 2009
That just happend to my great grandmother. You need to ask a clock maitnace person. Because it might Be you just need grease or a new motor so you also have to see if it' something that you want to fix an keep or get rid of.
Posted on Nov 12, 2008
The pendulum on my grandfather clock no longer works .. It is not a problem with batteries . It just no longer moves .
wind the spring up
if is battery operated replace the battery that swings the pendulum
Aug 30, 2017 | The Watches
I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
Howard Miller Grandfather Clock
Dec 06, 2016 | The Watches
I believe the grandfather clock I was given was over wound by the previous owner. Is there anyway that I can fix this myself so that it is affordable?
If you have the patience, you could try the following.
Set the pendulum in motion - this will slowly wind down the mainspring. The clock will probably stop after a few seconds. Set the pendulum swinging again as necessary, and if you're lucky the period that it ticks for will increase each time.
You will need to be patient and persevere - what you are doing is very gently releasing the tension on the mainspring.
This is not guaranteed to resolve the problem, but it won't harm the clock or your bank balance to try. Failing that, there is a mechanical fault that is causing it not to wind and you are strongly advised to place it in the hands of a reputable and competent clock repairer.
Aug 23, 2017 | Watches
Edward Meyer 31 Day Grandfather Clock manual
I recently bought an Edward Meyer clock from Grandfather clocks for less. The clock is beautiful, but it never chimed. I even took it apart and repaired the chimes, the hammers were too far away from the chiming rods, but now that it does chime, it sounds like someone banging pots and pans together, it's horrible. I've been looking online to find replacement chime and hammer parts so I can fix it myself.
Jan 23, 2012 | Watches
How do you control how fast or slow a grandfather clock runs ? Does lowering the pendelum disc make it faster or slower ? Thank you !!!
The longer the pendulum the slower it will swing, so lowering it will slow the clock down.
Feb 10, 2011 | Watches
Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
Jan 01, 2011 | Watches
Coaster model 900723 grandfather clock doesn't keep time
Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
Nov 20, 2010 | Watches
Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
Jan 28, 2010 | Watches
The pendulum stopped swinging...the clock and chimes work well
Hi
This clock short of needing a full service may simply be out of beat.
Taken from my web page located at:
http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
"HOW TO PUT YOUR CLOCK IN BEAT"
-Included below is a 10-second sound <snip> of a clock both in and out of beat.
IN BEAT ////////\\\\ OUT OF BEAT
· Turn on your sound and click on the clocks above for a sound clip.
-One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
-I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
-As I'm sure we now realize a clock must be in beat but not always level to function properly.
· Above is the verge with a slip clutch.
· Often found on Grandfather clocks and requires only a long swing to get it in beat.
-To get the clock on the right side in beat you would need to push the verge assembly to the left.
-If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
R/ David
Nov 08, 2009 | Seiko Chiming Pendulum Tambour Mantel...
Watches Logo
457 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
