Question about Sony KV-32S26 32" TV
KV- 32V40 Fusible resistor always blow-up
One day Iwas watching the ppv movie and suddenly I heard a clicking sound from my tv and shutdown no display or anything, just flashing red "LED". I opened the cover and found that the fusible resistor was open. I replaced it 3x and 3x blew up. Any idea where the problem is?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Hey...glad im not the only one in this mess....thank god i have an electronics background as i my offer some help. i found that Q601/Q602 were shorted,replaced with NTE2582 transistors, but also there is another fusible resistor located next ti the transformer on the powersupply board(board G i believe)same as the other(1/4-1/2 watt .1-.15 omhs)well i thought all was well until i pluged it in and both fusible resistors and the transistors blew right away....led me to the H-OUT transistor, right next to the flyback, on the main board...sure enough it was shorted as well. that part is 2SC5148(not the NTE part #), , and will put it in after work tommorow...looks good so far and will, even with my mistake will cost several hundred dollars less than taking it to a tv shop...and thousands less that the plasma screen the wife wants....this 32inch has been good to me for 9 years, and im going to help it along for another if possible. you cant email me at kellysheros@aol.com if youd like.....thanks and good luck
Posted on Jan 04, 2007
Streaming with DishNetwork
There is a difference in the PPV movies and the On Demand movies. You can only watch the PPV movies at certain times. If you purchase them and it has already started, you will not be able to watch it until the next start time. Or any start time thereafter for a period of 24 hrs.
Jan 04, 2013 | DISH Network ViP622 DVR DTV Receiver /...
Sony KV-32V40
I'll let you know if the user manual is available.
Jun 09, 2008 | Sony KV-32V40 32" TV
Sony tv wont turn on, standby light just flashes
check for an open resistor on the power supply, it is actually a fusible resistor, (white) if open, then check the converter, some sets have two separate and some have it as one. it will be on a heat sink on the power supply. if shorted then check for a shorted horizontal output transistor and repair cold solder joints on the horizintal drive transformer which is the real cause of this problem
Jan 07, 2009 | Sony KV-27S46 27" TV
After loading the DVD into the Go Video DVD/VCR Combo player the T.V. displays "Bad DVD" or "DVD Bad"
i have problem with my yto dvd player while iwas watching my favorite movie suddenly the pscan appear on my tv can you please me how to remove the said pscan i will appreciate it very much if u can help me thank u very much in advance
Oct 09, 2008 | GoVideo Televison & Video
KV-32V40 32" TV Problem:
Need a little information here...
1. The TV remains on with no picture, but the sound is fine?
2. How many blinks does the standby light give? Are they continuous? Is it the same each time, or random?
3. Did anything else happen before this, or did it just happen one day?
Answer that and I'll try to help with what I know.
This problem is indicative of a problem with one of three (of the same) ICs. Give me a bit more info and I'll give you some links to the solution, or help you myself.
Nov 24, 2007 | Sony KV-32V40 32" TV
No picture but sound ok
HI,YOUR PROBLEM IS ON THE FLYBACK TRANSFORMER OF YOUR TV. YOU MUST REPLACE THIS BUT BE VERY CAREFUL REMOVING THE FLYBACK.
Nov 22, 2007 | Sony KV-32V40 32" TV
Sony KV-32S36 32" suddenly stopped working, no picture or sound
Check soldered in fuse R607 in power supply circuit =
If open, replace it and bad converter xistors ( 2SC4834)
Next, replace shorted horizontal output transistor w/ first Quality.
Solder any / all bad connects,esp.horiz drive to base of horiz.
o / p xistor. Soldering is critical or it will blow up again......
Oct 27, 2007 | Sony KV-32S36 32" TV
Stand-by LED blinks-no picture or sound
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, video if,sound if, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician
Jan 16, 2007 | Sony KV-32V40 32" TV
Tv shuts off - sony kv-32v40
They are very relevant because you might have a high voltage ark from the output transformer or a shorted picture tube,the ark or high voltage leak you might not see but the shorting of the picture tube you will when it does it,being careful remove the back cover and leave the back open,turn the tv on and wait for the moment the shutdown takes place and look at the neck of the picture tube and thru the glass of the tube you might see the moment it shorts out and the set shutsdown,if you see something in the neck of the tube is because the tube is bad,take a look at the conections in the crt board maybe one of them is loose,the arking or leakage from the output transformer is dangerous and it should be observed from a safe distance(10 feet),if you notice something in the output transformer he will need to be replaced,both situations involved high voltage areas and if you are not too familiar with tv service you should get the assistance of a servicer.It is a good idea to resolder the main board if the two possibilties do not show or when the main problem is corrected.Let Us know how it goes or if you need more information.
Oct 31, 2006 | Sony KV-32V40 32" TV
Sony kv-32v40 Screen blins on and off
Increasing the screen control will not repair the problem,look for loose conections in the Horizontal driver transformer,readjustback the screen control.
Aug 25, 2006 | Sony KV-32V40 32" TV
Sony KV-32S26 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
