Question about Edimax Computers & Internet
How to change dns
I want to change dns for my edimax router
    Scholar:
  • 84 Answers
I am not familiar with Edimax, personally...however, you can find out a lot of information by understanding a bit about the computer attached to it.
Assumptions:
It's a home network
You are running a Windows machine
Your windows machine is connected to the Edimax router
Your Edimax router is also your default gateway
drop to a command prompt (start, run, CMD, enter)
Type ipconfig and hit enter
This will get you your IP address of your local machine as well as the subnet mask and the default gateway.
Once you have the default gateway, you can connect to it via Internet Explorer. You will need to set it up as http://192.168.1.1 (where the IP address is your default gateway)
At that point, you will need your router password
Once you get in, you can then poke through your settings and manually change the ones you need.
Hope this helps.
Posted on Nov 11, 2008
How can i change the SSID on my EDIMAX router BR-6428nS
Please download your router's user manual from here, and see page 45; there you will find your solution for change SSID of your Wireless network.
http://www.edimax.com/images/Image/manual/Wireless/BR-6428nS/BR-6428nS_Manual.pdf
Jan 21, 2014 | Edimax 4 Port Wireless AP Broadband Router...
I dont know where to ask this, if in pldt dsl or here.. dsn used for tplink is 4.2.2.4 how about for edimax router??
DNS servers are not router specific. The address 4.2.2.2 can be used but you may see a better increase by using googles public DNS servers at 8.8.8.8 and 8.8.8.4.
DNS servers simply resolve web address such as www.google.com into an IP address
Mar 01, 2011 | Computers & Internet
Dhcp disabled
I'm not too sure how you are trying to access the router (wired or wireless) or what operating system you are using, but you will need to manually set your IP address (through Network Properties) on the computer to 192.168.2.10 (for example) with subnet mask of 255.255.255.0.
If you also want internet access you will need to set the Gateway and DNS to 192.168.2.1.
Once that is set you will be able to try bring the page http://192.168.2.1 again and configure the router from there.
Once you configure the router (i assume you want to turn on DHCP again) you can set your computer back to DHCP assigned IP and DNS.
Dec 15, 2008 | Edimax BR-6104K Router (br6104k)
Edimax Router BR-6204WG - setting as
I believe I can help.
As I understand you use your Siemens to get to Internet and you like to use another Edimax 6204 WL Router on another floor.
You don't have to change much !
First check if DHCP on your Siemens Router is ENABLED (it should be) !
- RESET your EDIMAX Router (to be sure everything is set by default)
and disconnect any LAN cables from it.
- If you are using Laptop (or desktop with WL adapter), connect it to your EDIMAX by LAN cable.
- Set (if it is not) LAN adapter IP and DNS of your Laptop/Desktop
to 'Obtain an IP address automatically'
If it was seto to some STATIC IP, after this you may need to 'REPAIR' your LAN connection
to get a new IP from your Edimax router
- Open your browser and type http://192.168.2.1
(admin + pass: 1234)
- Go to Wan port and check it. It should be set to Dynamic IP.
- Go to LAN settings and type IP address of the Edimax Router in the same Class
as Siemens Router is. (e.g. if Siemes router is 192.168.1.1 then Edimax should be 192.168.1.2)
- Change the DHCP range too, but be carefull this range should be different from DHCP range on your
Siemens router. (e.g. if Siemens router range is 192.168.1.100 to 192.168.1.200, then you should
set Edimax DHCP range from 192.168.1.201 to 192.168.1.250)
- Now, connect the LAN cable from one of Siemens LAN port to WAN port of your Edimax.
That's it!
Now you may change SSID, Security, Time etc. on your Edimax router, and also try to connect via your Laptop's WL adapter. (also make sure it has no static IP address)
Hope this helped.
Aug 30, 2008 | Edimax BR-6104K Router (br6104k)
My edimax prob.
Hi...
Use the setup wizard under Internet Explorer - (go to: Tools, Internet Options, Connections, Setup) Choose the right connection after the setup... close the IE browser and reload it... If it doesn't work... you have to set the IP and DNS to Auto.... keep me posted if your still have problems.
Lost contact between PCs connected via AP
Set all the PC's to have a manual IP rather then using the DHCP from the router.
Also set the Gateway and Preferred DNS on the network cards to the routers IP (IE 192.168.0.1)
Apr 18, 2008 | Edimax EW-7206APg (EW7206APG) 802.11b/g...
Edimax BR-6104K Router Problem:
what type of modem do you have ie is it dsl using a username and password or a cable modem.
they are 2 different setups
cany you post an update here
Nov 05, 2007 | Edimax BR-6104K Router (br6104k)
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
Installation problem with edimax 6104kp
Hi Omdi,
Please proceed with the following instruction as follow.
1.) Connect first the modem to your pc, if you find it is working then get the IP Address, Subnet, Gateway, Primary DNS, Alternative DNS at the network properties TCP/IP.
2.) Open your router where you can configure the static IP or manually enter the IP address, subnet, gateway, primary dns, alternative dns.
3.) Make it sure you used the cable properly by connecting it to the appropriate line. For the modem to router you should connect the cable to WAN port. And the LAN port must be go through the computer.
If you still experience the problem, please let me know.
Best regards,
Philip
Oct 02, 2007 | Edimax BR-6104K Router (br6104k)
DNS problem
Hello, first of all where is your DNS coming from, do you use a server or is it from your ISP? If its from your ISP then add it statically, either call them or do an IPCONFIG /all form your command prompt you will see it there. Then add it...in your router under status doesn't it give you a public address and servers? anyway try that it should work...also if you use a server with DNS add that to the NIC as the first 1. Cheers!!!
Mar 08, 2007 | Edimax BR-6104 Broadband Router. One...
Computers & Internet Logo
268 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
